Devices and Printers Dialog Box Empty
2009-10-30T22:04:54+00:00
When I open my "Devices and Printers" dialog box, it is empty; nothing shows up and the item listing says "0 items".
The devices and printers showed up in the Devices and Printers dialog box earlier, but now are gone from the dialog box.  However, they are still in the system as everything seems to work.  The problem comes with trying to set the preferences for any of the devices or printers since they can't be seen or accessed.
Anyone got any ideas of how to get the devices and printers to show up again?
2010-03-07T06:22:04+00:00
Devices and printers will show one device when you have configured multiple printers for the same device.   There is a fly out menu to get to all the other printers on the device.    Use the spooler teams UI, printmanagement.msc to view all local printers on Pro and Ultimate.
The old printers folder can be launched if you are running Home versions.
Open a command prompt and paste this in.
start shell:::{26EE0668-A00A-44D7-9371-BEB064C98683}\0::{2227A280-3AEA-1069-A2DE-08002B30309D}
Alan Morris Windows Printing Team; Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/Default.aspx?adv=1
2009-11-27T18:23:06+00:00
I am having the same problem. I did a clean install from Vista and the computer has worked fine for weeks.  Today, my devices and printer window is empty. I can still print from some applications, but Windows Live Mail gives me an error when I select print:
'an error has occurred in the script on this page'
line:291
char: 1
error: interface not registered
Code: 0
URL: res://ieframe.dll/preview.js
Do you want to continue running scripts on this page - Yes or No?
Barry
By the way, no new hardware has been installed recently.
I found another post that solved my problem.  I was about to give up and re-install Windows 7, but tried this and it worked.
Go to: http://iefaq.info/index.php?action=artikel&cat=42&id=133&artlang=en
for the CMD file and explanation.
142 additional answers
    2010-03-29T22:08:19+00:00
    I have just noticed the same problem when I went to disconnect safely my usb drive.   There was nothing listed and when I opened "printers and devices" it was empty.   I never really use this feature as I don't have a printer, so it's no big deal.    The win7 forums suggest I do a repair install :  http://www.sevenforums.com/tutorials/3413-repair-install.html
    Haven't tried it yet but I don't see why it shouldn't work.  It seems to be less invasive than other suggestions here as it keeps all of the settings, apps and drivers.
    2010-03-30T14:07:22+00:00
    Maybe you have the Bluetooth problem reported above.
    Else, you don't even care, right. If I were you, I would not repair it.
    Just try the BT subject, or nothing.
    One day, Microsoft will solve this "empty window". Let's hope.
    PMoto
    2010-03-30T16:18:43+00:00
    PMoto
    Thanks, I did try the "enable BlueTooth" suggested fix but of course it did nothing.   At this point, for me it's not really causing a problem.  I have only one device connected, my external usb drive that I use for backups three times per week.    It still works fine.   The only difference is that now I'm just shutting it off when I'm finished instead of clicking the device icon to "safely remove"....    Hey - one step is saved, so it's actually more efficient ;-)
