How to locate and install my flash drive on my computer?
2010-09-28T01:09:51+00:00
I plug my flash drive into the usb port provided in the front part of my computer but I'm unable to located to look at my content.
2010-09-29T19:16:48+00:00
I would suggest you to check in the BIOS if it is disabled.
Here is the link for more information:
http://windows.microsoft.com/en-US/windows-vista/BIOS-frequently-asked-questions
Note: Modifying BIOS/complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
You can also check the mother board manual to know more about BIOS.
If that doesn’t help, then you need to check the connections in the system tower.
Azam – Microsoft Support.
Visit our **Microsoft Answers Feedback Forum** and, if you have any feedback you can post here.
121 additional answers
    2018-02-18T13:08:49+00:00
    Plugged in USB Nothing shows on screen How do I activate it?
    2018-02-20T23:43:40+00:00
    I clicked on the link. It gave me MANY options to choose from.
    Mother board manual?
    Connections in the system tower?
    Please respond in language that someone that is not computer savvy will understand.
  3. Deleted
    2018-02-21T17:07:45+00:00
    Check in the Bios?
    Check the mother board manual?
    Can you translate this to something simple that I will understand??
    I clicked on the link. All it did was give me more confusing information.
    If an answer was explained in language that someone is not computer literate could understand, that would be helpful.
    Thanks.
