How to locate and install my flash drive on my computer?
2010-09-28T01:09:51+00:00
I plug my flash drive into the usb port provided in the front part of my computer but I'm unable to located to look at my content.
2010-09-29T19:16:48+00:00
I would suggest you to check in the BIOS if it is disabled.
Here is the link for more information:
http://windows.microsoft.com/en-US/windows-vista/BIOS-frequently-asked-questions
Note: Modifying BIOS/complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
You can also check the mother board manual to know more about BIOS.
If that doesn’t help, then you need to check the connections in the system tower.
Azam – Microsoft Support.
Visit our **Microsoft Answers Feedback Forum** and, if you have any feedback you can post here.
121 additional answers
    2018-10-02T01:33:48+00:00
    how to find what is on this thumb drive I plugged into my pc
    2018-10-05T05:37:15+00:00
    why I am unable to use the flesh usb port provided that is showing uninstall or sizeable kind only .. does Microsoft try to make me unable to use it then why?
    2018-10-30T15:41:28+00:00
    How do you plug a flash drive into a usb port, when you don't even know where to get a flash drive to plug in
    2018-12-29T18:06:34+00:00
    I have inserted my memory stick into my computer but I am unable to retrieve the info
