How to locate and install my flash drive on my computer?
2010-09-28T01:09:51+00:00
I plug my flash drive into the usb port provided in the front part of my computer but I'm unable to located to look at my content.
2010-09-29T19:16:48+00:00
I would suggest you to check in the BIOS if it is disabled.
Here is the link for more information:
http://windows.microsoft.com/en-US/windows-vista/BIOS-frequently-asked-questions
Note: Modifying BIOS/complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
You can also check the mother board manual to know more about BIOS.
If that doesn’t help, then you need to check the connections in the system tower.
Azam – Microsoft Support.
Visit our **Microsoft Answers Feedback Forum** and, if you have any feedback you can post here.
121 additional answers
    2018-09-14T19:42:03+00:00
    My question is easier.  My USB stick is inserted, but I can't find on my computer.  Where do I do to open the USB stick?
    Open File Explorer (Windows key + e).  Do you see it there?
    2018-09-22T07:25:53+00:00
    OK maybe you should educate me as to the difference between USB 2.0 and USB 3.0 .  I saw a post in this that CLEARLY SHOWS the difference.  USB  3.0 ports ARE BLUE.
    the port is silver HP15
    2018-09-22T07:31:01+00:00
    I only have 2 ports on the side . 1 is used for the wireless mouse 1 is used for the cruzer glide 32 gb. I got a new HP15 since I put it in this new computer I can't read my games on the cruiser glider what do I do. I know nothing about computers
    2018-09-28T16:16:37+00:00
