How to locate and install my flash drive on my computer?
2010-09-28T01:09:51+00:00
I plug my flash drive into the usb port provided in the front part of my computer but I'm unable to located to look at my content.
2010-09-29T19:16:48+00:00
I would suggest you to check in the BIOS if it is disabled.
Here is the link for more information:
http://windows.microsoft.com/en-US/windows-vista/BIOS-frequently-asked-questions
Note: Modifying BIOS/complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
You can also check the mother board manual to know more about BIOS.
If that doesn’t help, then you need to check the connections in the system tower.
Azam – Microsoft Support.
Visit our **Microsoft Answers Feedback Forum** and, if you have any feedback you can post here.
121 additional answers
    2015-11-14T19:12:37+00:00
    I am able to use the USB port for my Iomega portable hard drive, but none of the flash drives are recognized.
    This problem may occur if upper and lower filters are being used in the registry and are corrupted. I don't understand this.
    It also mentions Windows automatically updating these drivers. I don't think my computer is set up to download drivers.
    2016-03-17T21:20:17+00:00
    When I plug in any device such as a  USB flash drive, I need my computer to recognize it?  Immediately.  But Windows 10 does not?
    I need a "step by step"  procedure.  Why do previous versions of Windows work with Flash drives and Windows 10 does not?
    2017-04-24T14:49:06+00:00
    Anybody have the answer?
  4. Deleted
