How to locate and install my flash drive on my computer?
2010-09-28T01:09:51+00:00
I plug my flash drive into the usb port provided in the front part of my computer but I'm unable to located to look at my content.
2010-09-29T19:16:48+00:00
I would suggest you to check in the BIOS if it is disabled.
Here is the link for more information:
http://windows.microsoft.com/en-US/windows-vista/BIOS-frequently-asked-questions
Note: Modifying BIOS/complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
You can also check the mother board manual to know more about BIOS.
If that doesn’t help, then you need to check the connections in the system tower.
Azam – Microsoft Support.
Visit our **Microsoft Answers Feedback Forum** and, if you have any feedback you can post here.
121 additional answers
    2018-09-01T04:38:28+00:00
    NOTE the top of the screen where the question begins "I plug my flash drive into the usb port provided in the front part of my computer but I'm unable to located to look at my content."
    THIS is the subject of the following discussion you then said "I have several USB drives that work just fine". So like I asked you "is it only one flash drive that fails to work?" IF so i would suggest as a computer repair man that that drive has failed.
    I responded to you, not the original post.  I responded because you made a very confident wrong statement in a July 31 reply to the OP:  "You probably got stuck buying a (new) USB 3.0 drive  they are NOT comparable [sic} with win 10."   Note the emphasis on "not."  Lest anyone who doesn't know better read that and think that it's true, I replied that there is no general compatibility problem between USB 3.0 and Windows 10.  Somehow you've managed to interpret that as me complaining about a flash drive not working.  As I've already explained, USB 3.0 flash drives work just fine in Windows 10 in both 2.0 and 3.0 ports on my computer.
    I recently purchased a pcie card that will support USB 3.0 my computer does not support USB 3.0 .. so thats why I purchased the card that does support USB 3.0  4 ports...on the back of my computer now supporting USB 3.0.  my computer is only 3 yrs old with win 10 installed.
    2018-09-03T06:09:21+00:00
    I plug my flash drive into my usb port but unable to view my content
    2018-09-03T13:27:11+00:00
    Be sure to identify a USB 2.0 from a USB 3.0 drive USB 3.0  Ports are BLUE USB 2.0 Ports are Black. USB 2.0 drives do not work in a USB 3.0 Port. USB 3.0 drives do not work in a USB 2.0 Port . Some drives are interchangeable USB 2.0 and USB 3.0  ....
    2018-09-03T14:31:12+00:00
    Your fifth sentence contradicts the third and fourth ones.
