How to locate and install my flash drive on my computer?
2010-09-28T01:09:51+00:00
I plug my flash drive into the usb port provided in the front part of my computer but I'm unable to located to look at my content.
2010-09-29T19:16:48+00:00
I would suggest you to check in the BIOS if it is disabled.
Here is the link for more information:
http://windows.microsoft.com/en-US/windows-vista/BIOS-frequently-asked-questions
Note: Modifying BIOS/complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
You can also check the mother board manual to know more about BIOS.
If that doesn’t help, then you need to check the connections in the system tower.
Azam – Microsoft Support.
Visit our **Microsoft Answers Feedback Forum** and, if you have any feedback you can post here.
121 additional answers
    2018-04-09T17:04:18+00:00
    Where is the flash drive I put in the usb port provided in the front part of my computer
  2. Deleted
    2018-04-10T22:47:36+00:00
    It is resolved, thank you everyone.
    2018-04-11T08:52:12+00:00
    Asover -92 years of ago, I am not reall good at the Computer, so if somerhing is important for me pkease just do it. Thank you fot All your Services. Alfred
