A one-click fix for Windows Update problems - How do I reset Windows Update components ?
Reported
2009-05-26T15:55:37+00:00
I can't check for, download or install updates through Windows Update.  HELP!
106 additional answers
    2009-06-01T18:58:59+00:00
    ya i think so. how do i get to them to check?
    2009-06-01T19:09:37+00:00
    hey, if i've done it right then this is what came up in notepad without me deleting anything. i did a search in system 32 and it came up with hosts and i double clicked and opened with notepad and got this
    Copyright (c) 1993-2006 Microsoft Corp.
    This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
    This file contains the mappings of IP addresses to host names. Each
    entry should be kept on an individual line. The IP address should
    be placed in the first column followed by the corresponding host name.
    The IP address and the host name should be separated by at least one
    space.
    Additionally, comments (such as these) may be inserted on individual
    lines or following the machine name denoted by a '#' symbol.
    For example:
    #      102.54.94.97     rhino.acme.com          # source server
    #       38.25.63.10     x.acme.com              # x client host
    127.0.0.1       localhost
    ::1             localhost
    2009-06-01T19:12:39+00:00
    so if thats the sample how do i get to the original :S
    2009-06-01T19:36:37+00:00
    That is the original. Don't go by the verbiage.
    Can the system access MalwareBytes.org ?
    Is the system networked via a router ?
    MowGreen MVP Data Center Management - Update Services Consumer Security
