A one-click fix for Windows Update problems - How do I reset Windows Update components ?
Reported
2009-05-26T15:55:37+00:00
I can't check for, download or install updates through Windows Update.  HELP!
106 additional answers
    2009-06-01T17:44:00+00:00
    oh my other bit didn't post :S i can't download the checkSUR for vista as internet explorer is saying internet explorer cannot display this webpage :S it does this when i click on link from MSN messanger aswell but it didn't do it before! like for example, now you can join people's network through msn and when u get a request for someone to join yours you get a notification on your MSN, well when i click on it, it says internet explorer cannot display this page as well, but it didn;t do it before. hope this helps! thanks
    2009-06-01T17:55:08+00:00
    This entry:
    2009-06-01 18:34:08:521 1208 d64 Setup FATAL: SelfUpdate check failed, err = 0x80244019
    may be an indication that the system is infected. See this MSKB, please:
    http://support.microsoft.com/kb/959894
    Follow the steps listed under " Resolution ".
    MowGreen MVP Data Center Management - Update Services Consumer Security
    2009-06-01T17:58:07+00:00
    hi, i've tried to download this before as someone told me to try it but i can't becuase it says that internet explorer cannot display the page
    2009-06-01T18:49:01+00:00
    Tried to download what, the MSRT ? If IE can't download it then that's a sure sign that the system is infected.
    See if there are any entries in the hosts file that are blocking downloads from security-related sites.
    Hosts is located in WINDOWS\System32\drivers\etc
    Double left click on hosts and open it with Notepad.
    If no sites have been added to the hosts file, then the last line should be
    ::1     localhost
    IF you see any entries that show microsoft.com and malwarebytes.org that look like these
    127.0.0.1  microsoft.com
    127.0.0.1  update.microsoft.com
    127.0.0.1  download.microsoft.com
    127.0.0.1  download.windowsupdate.com
    127.0.0.1  malwarebytes.org
    delete them. Close the hosts file by clicking File, then Save.
    Now see if IE can reach http://www.malwarebytes.org/mbam.php
    If it can, than download, install, update, and then run Malwarebyte's Anti-malware.
    Be sure to click the Download free version button.
    Do the Quick Scan first [ the Default scan option ]
    Could you do the above ?
