A one-click fix for Windows Update problems - How do I reset Windows Update components ?
Reported
2009-05-26T15:55:37+00:00
I can't check for, download or install updates through Windows Update.  HELP!
106 additional answers
    2010-04-10T17:28:55+00:00
    it's a good read with many good answers but as always the thread gets waayyy too confusing, best advise is to start a new question then someone can help without all the confusion.
    2010-04-21T04:42:50+00:00
    Steve I hope this "Fix it " solution works. :o) Thank you either way*. I used  MSI Windows Cleanup Utility to remove Net ad now I am not exactly certain as to how to re-install or if Windows Updates will automatically do this? One article said to go to : heck I think I've got it ! I hope, c/ya...... But just in case I do not I'll be back w/you.*
    2010-06-16T15:45:36+00:00
    Hi I have been following this thread to see if his problem and your answers could relate to my virus problem. which i think it does.
    So i have download the Malwarebytes that you advised him(hellandbliss) to do and installed it and is running as i type.
    I'm currently in consultation with PCtools Support as the purchase of Spyware Doctor yesterday didn't remove the virus nor has MSE which i loaded on after Microsoft closed LiveOne Care (Which worked for me for years without any problems.) Even with all the support out there i think these forums could be the answer The worst scenario is that i have to re-format my hard drive This virus won't allow me to update any security issues. nor backup my computer.
    Just to let you know the program that i was running above a quick scan has finished with 40 objects as infected What do you suggest. Regards Steve
    2010-06-29T20:19:47+00:00
    I tried this on my windows 7 pc to no avail. then realized it was probably for vista. Is there a windows 7 version???
