A one-click fix for Windows Update problems - How do I reset Windows Update components ?
Reported
2009-05-26T15:55:37+00:00
I can't check for, download or install updates through Windows Update.  HELP!
106 additional answers
    2010-03-02T04:41:20+00:00
    The Fix It thing did not work.
    After running the program it says This Fix It failed to process.
    I really need some help here!  Tired of reading so many different solutions, trying them and they never work!
    2010-03-04T03:37:39+00:00
    Hello All!
    I have loaded "Fix it" But it does eliminate the issue.
    Or, I can not find this below in Regedit to delete?
    HKLM\Software\Microsoft\Windows\CurrentVersion\Run\Microsoft auto update = WUAUCLT.EXE
    Any suggestions?
    Thanks.
    Joe
    2010-03-21T20:45:38+00:00
    This did not work for me. I got the message that the 'Windows Installer Service could not be accessed. This can occur of the Windows Installer is not correctly installed. Contact your support personnel for assistance'.  Did the above question ever get answered?
    Charleei
    2010-04-08T21:07:58+00:00
    Thanks Steve, fixed it.
