A one-click fix for Windows Update problems - How do I reset Windows Update components ?
Reported
2009-05-26T15:55:37+00:00
I can't check for, download or install updates through Windows Update.  HELP!
106 additional answers
    2009-07-27T16:36:54+00:00
      I am getting this error.... WindowsUpdate_800F0825 will this button fix my issues.... I had used it from another page and it allowed me to update some of the new updates but I still have one left that it won't allow me to download.... and when I start my computer it says that it can't find updater.exe.... please help...  Shayla
    From the bottom of the How do I reset Windows Update components page:
    Did this fix the problem?
    Check whether the Windows Update components are reset. If the Windows Update components are reset, you are finished with this article. If the Windows Update components are not reset, you can contact support .
    We would appreciate your feedback. To provide feedback or to report any issues with this solution, please leave a comment on the "Fix it for me " blog or send us an e-mail message.
    MowGreen MVP Data Center Management - Update Services Consumer Security
    2009-08-12T01:14:27+00:00
    That was the most optimistic title choice I've ever seen - for a 61 post thread about how Windows can't download files and run them.
    Aaron Oxford - Remember you paid them money for this!
    2009-08-12T07:33:01+00:00
    I tried the "Fix it" solution in both modes and it failed to fix windows update on my system. I then looked at "How do I reset Windows Update components" in the message from MowGreen below. I have not gone through all of the manual steps, but I did notice two interesting things. One is that msxml.dll is missing from my \windows\system32 directory. In fact, search cannot locate it anywhere on my machine. The other is that based on a suggestion I found on another website, I ran regsvr32 msxml3.dll (which is one small step in the instructions for resetting Windows Update), and whether I ran the command prompt as administrator or just through my administrator account, I received the message: "The module msxml3.Dll was loaded but the call to DllRegisterServer failed with error code 0x80004005."
    Could the missing file and this error help account for the failure of the "Fix it" solution? If so, what can I do about either?
    Thank you,
    Yechiel
    2009-08-12T17:30:32+00:00
    Optimism and Reality collide sometimes . <w>
