A one-click fix for Windows Update problems - How do I reset Windows Update components ?
Reported
2009-05-26T15:55:37+00:00
I can't check for, download or install updates through Windows Update.  HELP!
106 additional answers
    2009-07-08T18:28:47+00:00
    Ok, I had done a disk check from properties before, but I just did it again anyway. Unfortunately, I had to finish making supper and wasn't at the computer when it finished and continued to boot to windows. Where do I find a log of what it found, fixed and recovered? I don't know how to read the CheckSur log. If I posted some of it would you please tell me if it's missing anything? If so let me know how much you would like to see as it's QUITE long lol.
    Was chkdsk run with the volume offline via an Elevated Command Prompt ? AFAIK, the Application event log shows the result of a chkdsk in XP. Since I haven't run one in Vista yet ... suggest you check there. <w>
    Post the section of the CheckSUR.log from the most recent dateyou ran it, please. We don't need to see the entire log.
    SFC/scannow question: This computer is an Acer and came without a Windows disc. Isn't it pointless to run SFC/SCANNOW if you don't have the Vista disc for repairs? I have an Ultimate disc, (his version is home premium) can I use it? I'm thinking that unless it has completely different registries wouldn't the repair option just pick the data it needed to fix the Home premium and ignore the extra stuff that Ultimate has? If I CAN'T do that, can I use an x86 disc of Home Premium or are the versions sold to the computer manufacturers different than the OEM and Retail versions that I can buy? At just $89.00 for an OEM copy of Home premium at newegg, I have suggested he buy one to fix this and for any problems he may have in the future. I was hoping that if he does buy a copy, we can just pop it in and do a repair or SFC/SCANNOW than a complete re-install. Are any of these things an option?
    EDIT: Ok, I answered a few of my question by running SFC, but now I have new ones. I found KB 929833 "How To Use the System File Checker Tool to troubleshoot missing or corrupted system files on Windows Vista or Windows 7." However I am not certain how to interpret the results.
    I typed the command: "findstr /C:"[SR] Cannot repair member file" %windir%\logs\cbs\cbs.log >sfcdetails.txt" and hit enter. It gave me the cmd prompt again. I then typed the next one from the KB: "edit sfcdetails.txt" and hit enter. At that point I got a screen (which I don't know how to copy paste lol) which basically gave me 4 past files that couldn't be repaired and 4 from this recent scan. They ALL concern the Windows sidebar, which I have turned off and somehow doubt have anything to do with the computer failing to update. Have I done something wrong?
    Acer has a hidden partition that can restore the system back to it's factory Defaults. There should also be an option to burn a Vista Disk, which in effect, is a copy of Windows Vista. I think this burning option is present in Control Panel but don't recall precisely where.
    You should be able to copy and past what's listed in the sfcdetails.txt by pressing Ctrl+c to copy and Ctrl+v to paste.
    In fact, you should be able to navigate to sfcdetails.txt via Windows Explorer, copy the file to the Desktop, and then open it.
    You may need to agree to a consent prompt to copy it.
    Then open it and scroll all the way to the bottom.
    Then you can check for the files that can not be replaced/repaired.
    Then replace them using the steps laid out in KB929833
    MowGreen MVP Data Center Management - Update Services Consumer Security
    2009-07-08T18:35:11+00:00
    I tried the 'fix it' but it didn't work. I'm up to 22 updates that need to be installed now.
    any other ideas?
    Please start a new thread in the Windows Update forum , tjfaloon.
    Try another attempt at updating.
    If/when it fails , close the Windows Update window.
    Click the Start orb
    In the Start Search field type in windowsupdate.log
    Click the windowsupdate.log that is now showing and allow it some time to open.
    Scroll all the way to the bottom and copy&paste at least the last 50 or so lines into the thread you started.
    2009-07-08T20:01:31+00:00
    Below will be the ChweckSUR from today. As to the SFCdetails. Unless I'm mistaken, the only things that could not be repaired were the Windows sidebar things I mentioned above.
    CheckSUR Log for 7-08-09:
    2009-07-08 07:36:22, Info                  CBS    Loaded Servicing Stack v6.0.6002.18005 with Core: C:\Windows\winsxs\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.0.6002.18005_none_0b4ada54c46c45b0\cbscore.dll
    2009-07-08 07:36:22, Info                  CSI    00000001@2009/7/8:11:36:22.570 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x72058a50 @0x72fa854e @0x72f863a1 @0xbb1392 @0xbb1ed4 @0xbb17cb)
    2009-07-08 07:36:22, Info                  CSI    00000002@2009/7/8:11:36:22.680 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x72058a50 @0x72fde7b6 @0x72fc0f93 @0xbb1392 @0xbb1ed4 @0xbb17cb)
    2009-07-08 07:36:22, Info                  CSI    00000003@2009/7/8:11:36:22.680 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x72058a50 @0x73d91a0d @0x73d91794 @0xbb360b @0xbb2be3 @0xbb17cb)
    2009-07-08 07:36:22, Info                  CBS    NonStart: Checking to ensure startup processing was not required.
    2009-07-08 07:36:22, Info                  CSI    00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x9afbc8
    2009-07-08 07:36:22, Info                  CBS    NonStart: Success, startup processing not required as expected.
    2009-07-08 07:36:22, Info                  CSI    00000005 CSI Store 2157664 (0x0020ec60) initialized
    2009-07-08 07:36:22, Info                  CBS    Session: 30015424:1373098496 initialized.
    2009-07-08 07:36:22, Info                  CBS    Session: 30015424:1373098496 finalized.  Reboot required: no
    2009-07-08 08:15:45, Info                  CBS    Loaded Servicing Stack v6.0.6002.18005 with Core: C:\Windows\winsxs\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.0.6002.18005_none_0b4ada54c46c45b0\cbscore.dll
    2009-07-08 08:15:45, Info                  CSI    00000001@2009/7/8:12:15:45.349 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x71d98a50 @0x722b854e @0x722963a1 @0x941392 @0x941ed4 @0x9417cb)
    2009-07-08 08:15:45, Info                  CSI    00000002@2009/7/8:12:15:45.427 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x71d98a50 @0x722ee7b6 @0x722d0f93 @0x941392 @0x941ed4 @0x9417cb)
    2009-07-08 08:15:45, Info                  CSI    00000003@2009/7/8:12:15:45.443 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x71d98a50 @0x738d1a0d @0x738d1794 @0x94360b @0x942be3 @0x9417cb)
    2009-07-08 08:15:45, Info                  CBS    NonStart: Checking to ensure startup processing was not required.
    2009-07-08 08:15:45, Info                  CSI    00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x198f8ac
    2009-07-08 08:15:45, Info                  CBS    NonStart: Success, startup processing not required as expected.
    2009-07-08 08:15:45, Info                  CSI    00000005 CSI Store 2485344 (0x0025ec60) initialized
    2009-07-08 08:15:45, Info                  CBS    Session: 30015429:3524488587 initialized.
    2009-07-08 08:15:45, Info                  CBS    Session: 30015429:3524488587 finalized.  Reboot required: no
    2009-07-08 08:22:40, Info                  CBS    Loaded Servicing Stack v6.0.6002.18005 with Core: C:\Windows\winsxs\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.0.6002.18005_none_0b4ada54c46c45b0\cbscore.dll
    2009-07-08 08:22:40, Info                  CSI    00000001@2009/7/8:12:22:40.639 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x71d88a50 @0x722b854e @0x722963a1 @0x2e1392 @0x2e1ed4 @0x2e17cb)
    2009-07-08 08:22:40, Info                  CSI    00000002@2009/7/8:12:22:40.701 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x71d88a50 @0x722ee7b6 @0x722d0f93 @0x2e1392 @0x2e1ed4 @0x2e17cb)
    2009-07-08 08:22:40, Info                  CSI    00000003@2009/7/8:12:22:40.701 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x71d88a50 @0x73a41a0d @0x73a41794 @0x2e360b @0x2e2be3 @0x2e17cb)
    2009-07-08 08:22:40, Info                  CBS    NonStart: Checking to ensure startup processing was not required.
    2009-07-08 08:22:40, Info                  CSI    00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x1a3fad4
    2009-07-08 08:22:40, Info                  CBS    NonStart: Success, startup processing not required as expected.
    2009-07-08 08:22:40, Info                  CSI    00000005 CSI Store 1305696 (0x0013ec60) initialized
    2009-07-08 08:22:40, Info                  CBS    Session: 30015430:3382261299 initialized.
    2009-07-08 08:22:40, Info                  CBS    Session: 30015430:3382261299 finalized.  Reboot required: no
    2009-07-08 12:43:17, Info                  CBS    Loaded Servicing Stack v6.0.6002.18005 with Core: C:\Windows\winsxs\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.0.6002.18005_none_0b4ada54c46c45b0\cbscore.dll
    2009-07-08 12:43:17, Info                  CSI    00000001@2009/7/8:16:43:17.722 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x6e1a8a50 @0x6f22854e @0x6f2063a1 @0xc81392 @0xc81ed4 @0xc817cb)
    2009-07-08 12:43:17, Info                  CSI    00000002@2009/7/8:16:43:17.784 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x6e1a8a50 @0x6f25e7b6 @0x6f240f93 @0xc81392 @0xc81ed4 @0xc817cb)
    2009-07-08 12:43:17, Info                  CSI    00000003@2009/7/8:16:43:17.800 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x6e1a8a50 @0x743d1a0d @0x743d1794 @0xc8360b @0xc82be3 @0xc817cb)
    2009-07-08 12:43:17, Info                  CBS    NonStart: Checking to ensure startup processing was not required.
    2009-07-08 12:43:17, Info                  CSI    00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x164f7b8
    2009-07-08 12:43:17, Info                  CBS    NonStart: Success, startup processing not required as expected.
    2009-07-08 12:43:17, Info                  CSI    00000005 CSI Store 3992672 (0x003cec60) initialized
    2009-07-08 12:43:17, Info                  CBS    Session: 30015467:839456768 initialized.
    2009-07-08 12:43:17, Info                  CBS    Session: 30015467:839456768 finalized.  Reboot required: no
    2009-07-08 12:52:07, Info                  CBS    Loaded Servicing Stack v6.0.6002.18005 with Core: C:\Windows\winsxs\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.0.6002.18005_none_0b4ada54c46c45b0\cbscore.dll
    2009-07-08 12:52:07, Info                  CSI    00000001@2009/7/8:16:52:07.559 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x70f98a50 @0x7135854e @0x713363a1 @0x391392 @0x391ed4 @0x3917cb)
    2009-07-08 12:52:07, Info                  CSI    00000002@2009/7/8:16:52:07.575 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x70f98a50 @0x7138e7b6 @0x71370f93 @0x391392 @0x391ed4 @0x3917cb)
    2009-07-08 12:52:07, Info                  CSI    00000003@2009/7/8:16:52:07.575 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x70f98a50 @0x74441a0d @0x74441794 @0x39360b @0x392be3 @0x3917cb)
    2009-07-08 12:52:07, Info                  CBS    NonStart: Checking to ensure startup processing was not required.
    2009-07-08 12:52:07, Info                  CSI    00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x15afcd8
    2009-07-08 12:52:07, Info                  CBS    NonStart: Success, startup processing not required as expected.
    2009-07-08 12:52:07, Info                  CSI    00000005 CSI Store 2681952 (0x0028ec60) initialized
    2009-07-08 12:52:07, Info                  CBS    Session: 30015468:1842086041 initialized.
    2009-07-08 12:52:07, Info                  CBS    Session: 30015468:1842086041 finalized.  Reboot required: no
    2009-07-08 13:02:59, Info                  CBS    Loaded Servicing Stack v6.0.6002.18005 with Core: C:\Windows\winsxs\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.0.6002.18005_none_0b4ada54c46c45b0\cbscore.dll
    2009-07-08 13:02:59, Info                  CSI    00000001@2009/7/8:17:02:59.096 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x68cc8a50 @0x6901854e @0x68ff63a1 @0x21392 @0x21ed4 @0x217cb)
    2009-07-08 13:02:59, Info                  CSI    00000002@2009/7/8:17:02:59.189 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x68cc8a50 @0x6904e7b6 @0x69030f93 @0x21392 @0x21ed4 @0x217cb)
    2009-07-08 13:02:59, Info                  CSI    00000003@2009/7/8:17:02:59.205 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x68cc8a50 @0x72061a0d @0x72061794 @0x2360b @0x22be3 @0x217cb)
    2009-07-08 13:02:59, Info                  CBS    NonStart: Checking to ensure startup processing was not required.
    2009-07-08 13:02:59, Info                  CSI    00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x71f778
    2009-07-08 13:02:59, Info                  CBS    NonStart: Success, startup processing not required as expected.
    2009-07-08 13:12:59, Info                  CBS    Scavenge: Package store indicates there is no component to scavenge, skipping.
    2009-07-08 13:14:37, Info                  CBS    Loaded Servicing Stack v6.0.6002.18005 with Core: C:\Windows\winsxs\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.0.6002.18005_none_0b4ada54c46c45b0\cbscore.dll
    2009-07-08 13:14:37, Info                  CSI    00000001@2009/7/8:17:14:37.838 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x6f558a50 @0x73a7854e @0x73a563a1 @0x21392 @0x21ed4 @0x217cb)
    2009-07-08 13:14:37, Info                  CSI    00000002@2009/7/8:17:14:37.869 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x6f558a50 @0x73aae7b6 @0x73a90f93 @0x21392 @0x21ed4 @0x217cb)
    2009-07-08 13:14:37, Info                  CSI    00000003@2009/7/8:17:14:37.869 WcpInitialize (wcp.dll version 0.0.0.5) called (stack @0x6f558a50 @0x74941a0d @0x74941794 @0x2360b @0x22be3 @0x217cb)
    2009-07-08 13:14:37, Info                  CBS    NonStart: Checking to ensure startup processing was not required.
    2009-07-08 13:14:37, Info                  CSI    00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x14ef9b0
    2009-07-08 13:14:37, Info                  CBS    NonStart: Success, startup processing not required as expected.
    2009-07-08 13:14:37, Info                  CSI    00000005 CSI Store 2616416 (0x0027ec60) initialized
    2009-07-08 13:14:37, Info                  CBS    Session: 30015471:2460124133 initialized.
    2009-07-08 13:14:37, Info                  CBS    Session: 30015471:2460124133 finalized.  Reboot required: no
    2009-07-08T22:40:21+00:00
    It just occured to me to find and check the update log. Won't IT tell us what is going on? I don't know what to look for, but it seems as though it is using a proxy (which it shouldn't be I don't think) and also that it's not able to extract something it needs from a cab file. Here is the last attempt on in the log. Most of it is repeated tries and data, but I didn't know where to start and stop it. Does this help?
    2009-07-08 18:23:50:500 1188 d08 AU AU deferring detection until wake-up from hibernation
    2009-07-08 18:23:59:719 1188 d08 AU Triggering Online detection (non-interactive)
    2009-07-08 18:24:29:747 1188 d08 AU #############
    2009-07-08 18:24:29:747 1188 d08 AU ## START ##  AU: Search for updates
    2009-07-08 18:24:29:763 1188 d08 AU <<## SUBMITTED ## AU: Search for updates [CallId = {4F3F360C-704A-4826-9480-42B381191771}]
    2009-07-08 18:24:29:763 1188 4d8 Agent *************
    2009-07-08 18:24:29:763 1188 4d8 Agent ** START **  Agent: Finding updates [CallerId = AutomaticUpdates]
    2009-07-08 18:24:29:763 1188 4d8 Agent   * Online = Yes; Ignore download priority = No
    2009-07-08 18:24:29:763 1188 4d8 Agent   * Criteria = "IsInstalled=0 and DeploymentAction='Installation' or IsPresent=1 and DeploymentAction='Uninstallation' or IsInstalled=1 and DeploymentAction='Installation' and RebootRequired=1 or IsInstalled=0 and DeploymentAction='Uninstallation' and RebootRequired=1"
    2009-07-08 18:24:29:763 1188 4d8 Agent   * ServiceID = {7971F918-A847-4430-9279-4A52D1EFE18D}
    2009-07-08 18:24:29:763 1188 4d8 Agent   * Search Scope = {Machine}
    2009-07-08 18:24:29:763 1188 4d8 Setup Checking for agent SelfUpdate
    2009-07-08 18:24:29:763 1188 4d8 Setup Client version: Core: 7.2.6001.788  Aux: 7.2.6001.788
    2009-07-08 18:24:34:488 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:24:34:488 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.windowsupdate.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:24:34:488 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:24:34:488 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:24:34:488 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:24:38:778 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:24:38:778 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.windowsupdate.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:24:38:778 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:24:38:778 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:24:38:778 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:24:43:099 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:24:43:099 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.windowsupdate.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:24:43:099 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:24:43:099 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:24:43:099 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:24:47:389 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:24:47:389 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.windowsupdate.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:24:47:389 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:24:47:389 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:24:47:389 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:24:47:389 1188 4d8 Misc WARNING: DownloadFileInternal failed for http://download.windowsupdate.com/v8/windowsupdate/redir/muv3wuredir.cab: error 0x80072efd
    2009-07-08 18:24:51:711 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:24:51:711 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:24:51:711 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:24:51:711 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:24:51:711 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:24:56:001 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:24:56:001 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:24:56:001 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:24:56:001 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:24:56:001 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:00:291 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:00:291 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:00:291 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:00:291 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:00:291 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:04:581 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:04:581 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:04:581 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:04:581 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:04:581 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:04:581 1188 4d8 Misc WARNING: DownloadFileInternal failed for http://download.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab: error 0x80072efd
    2009-07-08 18:25:08:871 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:08:871 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:08:871 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:08:871 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:08:871 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:13:161 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:13:161 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:13:161 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:13:161 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:13:161 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:17:451 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:17:451 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:17:451 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:17:451 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:17:451 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:21:741 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:21:741 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:21:741 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:21:741 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:21:741 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:21:741 1188 4d8 Misc WARNING: DownloadFileInternal failed for http://update.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab: error 0x80072efd
    2009-07-08 18:25:21:741 1188 4d8 Agent WARNING: Failed to obtain the authorization cab URLs, hr=0x80072efd
    2009-07-08 18:25:26:031 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:26:031 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.windowsupdate.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:26:031 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:26:031 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:26:031 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:30:321 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:30:321 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.windowsupdate.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:30:321 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:30:321 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:30:321 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:34:626 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:34:626 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.windowsupdate.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:34:626 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:34:626 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:34:626 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:38:932 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:38:932 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.windowsupdate.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:38:932 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:38:932 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:38:932 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:38:932 1188 4d8 Misc WARNING: DownloadFileInternal failed for http://download.windowsupdate.com/v8/windowsupdate/redir/muv3wuredir.cab: error 0x80072efd
    2009-07-08 18:25:43:222 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:43:222 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:43:222 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:43:222 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:43:222 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:47:512 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:47:512 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:47:512 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:47:512 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:47:512 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:51:802 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:51:802 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:51:802 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:51:802 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:51:802 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:56:107 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:25:56:107 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://download.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:25:56:107 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:25:56:107 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:25:56:107 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:25:56:107 1188 4d8 Misc WARNING: DownloadFileInternal failed for http://download.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab: error 0x80072efd
    2009-07-08 18:26:00:397 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:26:00:397 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:26:00:397 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:26:00:397 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:26:00:397 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:26:04:703 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:26:04:703 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:26:04:703 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:26:04:703 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:26:04:703 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:26:09:071 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:26:09:071 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:26:09:071 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:26:09:071 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:26:09:071 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:26:13:361 1188 4d8 Misc WARNING: SendRequest failed with hr = 80072efd. Proxy List used: <http=localhost:7171> Bypass List used : <(null)> Auth Schemes used : <>
    2009-07-08 18:26:13:361 1188 4d8 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab>. error 0x80072efd
    2009-07-08 18:26:13:361 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x80072efd
    2009-07-08 18:26:13:361 1188 4d8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80072efd
    2009-07-08 18:26:13:361 1188 4d8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80072efd
    2009-07-08 18:26:13:361 1188 4d8 Misc WARNING: DownloadFileInternal failed for http://update.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab: error 0x80072efd
    2009-07-08 18:26:13:361 1188 4d8 Setup WARNING: SelfUpdate check failed to download package information, error = 0x80072EFD
    2009-07-08 18:26:13:361 1188 4d8 Setup FATAL: SelfUpdate check failed, err = 0x80072EFD
    2009-07-08 18:26:13:361 1188 4d8 Agent   * WARNING: Skipping scan, self-update check returned 0x80072EFD
    2009-07-08 18:26:13:377 1188 4d8 Agent   * WARNING: Exit code = 0x80072EFD
    2009-07-08 18:26:13:377 1188 4d8 Agent *********
    2009-07-08 18:26:13:377 1188 4d8 Agent **  END  **  Agent: Finding updates [CallerId = AutomaticUpdates]
    2009-07-08 18:26:13:377 1188 4d8 Agent *************
    2009-07-08 18:26:13:377 1188 4d8 Agent WARNING: WU client failed Searching for update with error 0x80072efd
    2009-07-08 18:26:13:377 1188 ee0 AU >>##  RESUMED  ## AU: Search for updates [CallId = {4F3F360C-704A-4826-9480-42B381191771}]
    2009-07-08 18:26:13:377 1188 ee0 AU   # WARNING: Search callback failed, result = 0x80072EFD
    2009-07-08 18:26:13:377 1188 ee0 AU   # WARNING: Failed to find updates with error code 80072EFD
    2009-07-08 18:26:13:377 1188 ee0 AU #########
    2009-07-08 18:26:13:377 1188 ee0 AU ##  END  ##  AU: Search for updates [CallId = {4F3F360C-704A-4826-9480-42B381191771}]
    2009-07-08 18:26:13:377 1188 ee0 AU #############
    2009-07-08 18:26:13:377 1188 ee0 AU AU setting next detection timeout to 2009-07-09 03:26:13
    2009-07-08 18:26:13:377 1188 ee0 AU Setting AU scheduled install time to 2009-07-09 07:00:00
    2009-07-08 18:26:18:369 1188 4d8 Report REPORT EVENT: {F8BC564C-BCAD-47C5-A756-2C5D723608B5} 2009-07-08 18:26:13:361-0400 1 148 101 {D67661EB-2423-451D-BF5D-13199E37DF28} 1 80072efd SelfUpdate Failure Software Synchronization Windows Update Client failed to detect with error 0x80072efd.
    When I copy pasted the address, http://update.microsoft.com/v8/windowsupdate/redir/muv3wuredir.cab into IE I got a popup that asked me to run or save so I AM getting something from there when I do it myself.
