System Interrupts Huge CPU Usage
2009-11-18T12:06:50+00:00
I have just recently installed Windows 7 Professional on my machine and I am having a problem with a process called System Interrupts using alot (25% approximately) of CPU.
I have tried several supposed fixes i have found here and on other forums but have not solved the issue.
I am at wits end.
http://i289.photobucket.com/albums/ll203/SK-illfull/systeminterrupts.jpg
Mobo: Gigabyte GA-EP35-DS3
Video Card: Nvidea 8800 GTX
2012-02-23T09:40:40+00:00
My computer got so slow that the mouse was slow and jerky and I had to reboot. System interrupts was at about 30% CPU time. My PC is now with 5 days uptime and the bug seems to have disappeared. The following solution seems to solve the issue :
  1. Right-click on the speaker icon
  2. Select playback devices
  3. Click on the speaker properties
  4. Go to the enhancements Tab
  5. Click Disable All Sound Effects
  6. Click OK. You're done!
The sound enhancements seem for some reason to cause the problem even when not used. So disable them following the procedure above. Good luck!
122 additional answers
    2013-03-28T07:36:22+00:00
    OK, but I installed the latest drivers from Nvidia but its not the source of the problem for me. The problem occurred when I had the Integrated GPU only. The Problem hasn't surfaced after I installed GT610 on my machine.
    2013-03-28T07:48:47+00:00
    I have the same question,and I have resolved it today!
    My computer is Lenovo y460,OS is Windows 8 Pro 64-bit.
    I remember that I have add a 4GB RAM(kingston) before,so I have 6 GB RAM(2 GB RAM made by Ramaxel),The caused System interrupts using 20%CPU.
    Today,I removed the 2 GB RAM,question resolved...
    I suggestion try to use 1 RAM in your computer.
    2013-04-02T10:21:19+00:00
    doesnt work man
    2013-04-02T14:53:51+00:00
    i think it's a problem with ntosKernel, ACPI.sys and Nvidia drivers. and every solution searched in "google" doesn't work, including clean format, exchanged drivers, reset, downgrade and upgrade bios, clean boot, disabled almost every device including nvidia drivers,
    Some users report the bug in win8, but I'm using win7 x64, maybe it's time to test win7 x32 but using only 4gb of ram.
    Also i changed the two ram slot with a GSkill 2x4gb when i bought my laptop.
