System Interrupts Huge CPU Usage
2009-11-18T12:06:50+00:00
I have just recently installed Windows 7 Professional on my machine and I am having a problem with a process called System Interrupts using alot (25% approximately) of CPU.
I have tried several supposed fixes i have found here and on other forums but have not solved the issue.
I am at wits end.
http://i289.photobucket.com/albums/ll203/SK-illfull/systeminterrupts.jpg
Mobo: Gigabyte GA-EP35-DS3
Video Card: Nvidea 8800 GTX
2012-02-23T09:40:40+00:00
My computer got so slow that the mouse was slow and jerky and I had to reboot. System interrupts was at about 30% CPU time. My PC is now with 5 days uptime and the bug seems to have disappeared. The following solution seems to solve the issue :
  1. Right-click on the speaker icon
  2. Select playback devices
  3. Click on the speaker properties
  4. Go to the enhancements Tab
  5. Click Disable All Sound Effects
  6. Click OK. You're done!
The sound enhancements seem for some reason to cause the problem even when not used. So disable them following the procedure above. Good luck!
122 additional answers
    2009-11-19T13:05:35+00:00
    Sorry it took so long to get back to you - I was working until midnight on a networking job. Thanks for the picture; it really helped. A quick Google for nvSCPAPisvr.exe shows that this service is connected with the Nvidia Stereoscopic 3D Driver Service and it is responsible for sucking up resources on a lot of people's systems:
    http://www.google.com/webhp?rls=ig#rls=ig&hl=en&source=hp&q=nvscpapisvr.exe&aq=1&aqi=g2g-s1g2g-s1g2g-s1g1&oq=nvSC&fp=5b7cf21b103219ea
    http://www.overclock.net/nvidia-drivers-overclocking-software/553294-why-nvscpapisvr-exe-using-700mb-ram.htmlTake a look at the links and then try disabling this unnecessary service and see if your computer behaves nicely now.
    MS-MVP - Elephant Boy Computers - Don't Panic!
    2009-11-20T03:12:13+00:00
    i disabled nvSCPAPisvr.exe in services.msc
    still i get huge cpu hogging from Deferred Procedure Calls/System Interrupts, the same as in previously posted screenshots
    2009-11-20T05:40:00+00:00
    did a PcMatic Pitstop scan.
    http://www.pcpitstop.com/
    according to the results all drivers are up to date
    2009-11-20T12:43:16+00:00
    bump la
