System Interrupts Huge CPU Usage
2009-11-18T12:06:50+00:00
I have just recently installed Windows 7 Professional on my machine and I am having a problem with a process called System Interrupts using alot (25% approximately) of CPU.
I have tried several supposed fixes i have found here and on other forums but have not solved the issue.
I am at wits end.
http://i289.photobucket.com/albums/ll203/SK-illfull/systeminterrupts.jpg
Mobo: Gigabyte GA-EP35-DS3
Video Card: Nvidea 8800 GTX
2012-02-23T09:40:40+00:00
My computer got so slow that the mouse was slow and jerky and I had to reboot. System interrupts was at about 30% CPU time. My PC is now with 5 days uptime and the bug seems to have disappeared. The following solution seems to solve the issue :
  1. Right-click on the speaker icon
  2. Select playback devices
  3. Click on the speaker properties
  4. Go to the enhancements Tab
  5. Click Disable All Sound Effects
  6. Click OK. You're done!
The sound enhancements seem for some reason to cause the problem even when not used. So disable them following the procedure above. Good luck!
122 additional answers
    2012-09-23T16:13:06+00:00
    i am haveing a similar issue where my CPU is continualy running at 100% right now it is harming my fraimrate for nearly a year now i've been swaping graphic cards thinking it was that but i found out it is all in the cpu and it is a system interupts that is causing me the highest processer overload. i've done all the suggestions up to this point and nothing is slowing it down. if there is anymore suggestions i would love to hear it. the only other thing i can think of is to get a new processer and that is just expensive as ****. but i see no other choice. because the current processer is either overloaded with a standered microsoft too lazy to program things and check them correctly bug or it is broken somehow..
  2. Deleted
    2012-12-22T23:20:00+00:00
    Thanks for the tip i was having the same probelm but with windows 8 and i did what you said and im already seeing a huge improvement in performance
    2012-12-28T12:33:49+00:00
    didnt work for me ;C....
    CAN ANYONE HELP!?????????!!
