System Interrupts Huge CPU Usage
2009-11-18T12:06:50+00:00
I have just recently installed Windows 7 Professional on my machine and I am having a problem with a process called System Interrupts using alot (25% approximately) of CPU.
I have tried several supposed fixes i have found here and on other forums but have not solved the issue.
I am at wits end.
http://i289.photobucket.com/albums/ll203/SK-illfull/systeminterrupts.jpg
Mobo: Gigabyte GA-EP35-DS3
Video Card: Nvidea 8800 GTX
2012-02-23T09:40:40+00:00
My computer got so slow that the mouse was slow and jerky and I had to reboot. System interrupts was at about 30% CPU time. My PC is now with 5 days uptime and the bug seems to have disappeared. The following solution seems to solve the issue :
  1. Right-click on the speaker icon
  2. Select playback devices
  3. Click on the speaker properties
  4. Go to the enhancements Tab
  5. Click Disable All Sound Effects
  6. Click OK. You're done!
The sound enhancements seem for some reason to cause the problem even when not used. So disable them following the procedure above. Good luck!
122 additional answers
    2010-11-24T15:25:19+00:00
    also make the xperf trace
    "A programmer is just a tool which converts caffeine into code" CLIP- Stellvertreter http://www.winvistaside.de/
    2010-12-15T08:03:53+00:00
    Had the same problem with Win7 Quad Core - constant 25% cpu load (1 core 100% cpu load) due to deferred procedure calls/interrupt service routines. Finally tracked the problem down to a pci ethernet controller I installed, which I have now disabled. The biggest trick is finding the cause - once found either update the driver or remove/disable the faulty hardware. Also if possible try moving the hardware to another slot.
    2011-01-14T15:13:47+00:00
    In my case it called dxgkrnl.sys the most. A simple search says it's part of DirectX.
    2011-01-26T19:23:03+00:00
    Hi all.
    Andre. i use ypur tutorial and i go to this :  http://img546.imageshack.us/i/48388487.jpg/
    Which is my problem?
