System Interrupts Huge CPU Usage
2009-11-18T12:06:50+00:00
I have just recently installed Windows 7 Professional on my machine and I am having a problem with a process called System Interrupts using alot (25% approximately) of CPU.
I have tried several supposed fixes i have found here and on other forums but have not solved the issue.
I am at wits end.
http://i289.photobucket.com/albums/ll203/SK-illfull/systeminterrupts.jpg
Mobo: Gigabyte GA-EP35-DS3
Video Card: Nvidea 8800 GTX
2012-02-23T09:40:40+00:00
My computer got so slow that the mouse was slow and jerky and I had to reboot. System interrupts was at about 30% CPU time. My PC is now with 5 days uptime and the bug seems to have disappeared. The following solution seems to solve the issue :
  1. Right-click on the speaker icon
  2. Select playback devices
  3. Click on the speaker properties
  4. Go to the enhancements Tab
  5. Click Disable All Sound Effects
  6. Click OK. You're done!
The sound enhancements seem for some reason to cause the problem even when not used. So disable them following the procedure above. Good luck!
122 additional answers
    2010-02-20T16:41:37+00:00
    Have you followed my guide and used xperf to make a trace when the spikes happen? Do you see which driver is causing it?
    "A programmer is just a tool which converts caffeine into code" CLIP- Stellvertreter http://www.winvistaside.de/
    2010-04-20T15:14:22+00:00
    I also have been having the same issue with Windows 7 Ultimate. Everything is up to date, drivers, windows updates. It seems to be a random event, but it happens every day, I can't predict how it happens or what program causes the issue.
    My Specs
    Motheborad: EVGA x58 chipset
    CPU: Intel Core i7 930
    RAM: 6GB
    HDD: Destern Digital Caviar black 1TB
    Optical: 1. Asus Bluray 2. Asus DVD-R/W
    Video: 8800GTS 640
    OS: Windows 7 Ultimate 64bit
    2010-04-20T19:01:38+00:00
    Have you run xperf as Andre suggested?
    2010-04-20T23:51:19+00:00
    please run xperf and look which driver causes the issue.
