See all 3 power plans on system tray
2009-10-01T03:29:27+00:00
Windows 7 is better than Vista in so many ways, but it's actually a lot worse in some others. Take, for example, choosing power plans from the system tray.
In Windows Vista, you could click on the battery meter and choose between the 3 plans: High Performance, Balanced, and Power Saver.
Now, for some idiotic reason, Microsft decided to limit our choices to only TWO plans from the system tray: your current plan + Balanced (if balanced is selected I believe it defaults to Power Saver for the 2nd one). To change it to the 3rd one I have to actually click on "More Power Options" and then select the plan.
Microsoft is requiring you to take extra steps for doing something that was easier before. I thought Windows 7's mantra was "do things faster" (i.e. Jumplists, Aero Peek, Accelerators, etc.) Who was the moron who made this decision, and how can I get my Vista-style Power tray back?
2009-10-03T17:27:31+00:00
Um maybe if you read my original post (or if use Windows 7 itself), Balanced is ALWAYS shown, even if it wasn't your 'old' plan. So you can't flip-flop between Power Saver and High Performance, which is what I want.
What if I deleted the Balanced power plan? Is there a way to delete the default plans?
Yes, there is a way.
FlyoutAutoPowerScheme: http://technet.microsoft.com/en-us/library/cc749282(WS.10).aspx
Rating posts helps other usersMark L. Ferguson MS-MVP
46 additional answers
    2009-11-30T22:31:19+00:00
    Dear moron helping to design Windows 7,
    Like the other users posted, it is indeed very frustrating when wanting to switch between Power Saver and High Performance. I did a little survey, and many users don't even use power plans, and the ones that do will not even use "Balanced".
    I am a gamer with a high performance laptop that occasionally has the need to save battery power. I've tweaked the settings of high performance and power saver to my needs. Back in Vista, the list showed recently used power plans, which was ideal for most users.
    This is not an issue over which most end users will re-format their computers and re-install with an answer file. And no one wants to install a 3rd party app that does this.
    Please include a fix for this in a future hotfix or service pack. And please keep me updated if there's a solution.
    2009-11-30T22:41:18+00:00
    info: > "No new features in Service Packs"
    solution: > You will have to accept one of the three or four workarounds, the power feature is by design, and expected behavior for Win 7.
    !\[\](http://i3.social.microsoft.com/Image.avatr?size=Large&user=Mark L. Ferguson&id=fb4a4625-6789-43eb-aa48-4a1fbf2df947)
    2009-12-09T15:17:18+00:00
    Hey. There exists a 100% working solution, a free software called "Power Plan Assistant for Windows7".
    Its website URL is www.powerplan7.com
    What Power Plan Assistant application is capable of:
    1. Switch between the Windows® built-in power plans (all power plans, including custom plans, not just 2 of them, as it is when operating via system Power icon);
    2. Easily observe which power plan is currently active (dynamic application icon in a taskbar notification area changes in accordance with an active power plan, does not matter where it has been changed - in a Control Panel, system Power icon or in the Power Plan Assistant itself);
    3. Instantly power off the display on user's demand (why wait at least one minute for it to be powered off, wasting the energy?). The display can be waked up then by pressing any key or moving the cursor;
    4. Switch the power plans automatically:
    • to 'Power Saver' (to preventively save the energy if the battery level goes low);
    • to 'High Performance' (on plugging in);
    • to 'Balanced' (on plugging out).
