See all 3 power plans on system tray
2009-10-01T03:29:27+00:00
Windows 7 is better than Vista in so many ways, but it's actually a lot worse in some others. Take, for example, choosing power plans from the system tray.
In Windows Vista, you could click on the battery meter and choose between the 3 plans: High Performance, Balanced, and Power Saver.
Now, for some idiotic reason, Microsft decided to limit our choices to only TWO plans from the system tray: your current plan + Balanced (if balanced is selected I believe it defaults to Power Saver for the 2nd one). To change it to the 3rd one I have to actually click on "More Power Options" and then select the plan.
Microsoft is requiring you to take extra steps for doing something that was easier before. I thought Windows 7's mantra was "do things faster" (i.e. Jumplists, Aero Peek, Accelerators, etc.) Who was the moron who made this decision, and how can I get my Vista-style Power tray back?
2009-10-03T17:27:31+00:00
Um maybe if you read my original post (or if use Windows 7 itself), Balanced is ALWAYS shown, even if it wasn't your 'old' plan. So you can't flip-flop between Power Saver and High Performance, which is what I want.
What if I deleted the Balanced power plan? Is there a way to delete the default plans?
Yes, there is a way.
FlyoutAutoPowerScheme: http://technet.microsoft.com/en-us/library/cc749282(WS.10).aspx
Rating posts helps other usersMark L. Ferguson MS-MVP
46 additional answers
    2009-10-09T08:06:14+00:00
    2009-10-09T20:44:55+00:00
    So, as I understand it, we have to re-install our Windows7 boxes from scratch to change such an small setting? It's not like I have 20 PCs that all run on batteries, and I certainly wouldn't need to install Win7 unattended on them, even if I did. I do thank you for the information and help you have provided.
    2009-10-10T02:31:20+00:00
    2009-11-21T12:55:26+00:00
    Such idiotic changes should be FIXED RIGHT AWAY IMMEDIATELY AT ONCE THRU A HOTFIX. ARE YOU LISTENING MICROSOFT?
    Anonymuos
