Force Feedback Wheel problems
2009-12-20T01:35:23+00:00
I have a Thrustmaster force feedback wheel that functioned perfectly under Vista service pack one. Since applying service pack 2 the machine will not boot, even in safe mode. Remove the wheel from the usb port, machine boots fine. Replug wheel , instant blue screen. Any ideas. All drivers are compatible according to Thrustmaster and Microsoft websites,
2009-12-20T20:22:50+00:00
Hi macdonald_ron,
Welcome to Microsoft answers!
I would suggest you to try the following steps:
**Step 1:**run the fixit provided in the link below.
http://windows.microsoft.com/en-US/windows-vista/Tips-for-solving-problems-with-USB-devices
 If the issue still persists,
**Step 2:**The drivers might have gone corrupt so, Uninstall and reinstall the drivers.
You must be logged on as an administrator to perform these steps.
1.         Open Device Manager by clicking the Start button, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.   If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
2.         In Device Manager, locate the device (mouse and the printer), and then double-click the device name.
3.         Click the Driver tab, and then click uninstall Driver and follow the instructions.
Check the link to manually re-install the drivers
Update a driver for hardware that isn't working properly via windows update
http://windows.microsoft.com/en-us/windows-vista/Update-a-driver-for-hardware-that-isnt-working-properly
Or install the latest drivers from the manufacturer’s website
http://ts.thrustmaster.com/eng/
Step 3: Connect the device to a different USB port and test.
If the issue persists,
**Step 4:**Reinstall USB controllers.
****First, please disconnect all USB devices and then perform the following steps:
1.    Click "Start", type in Device Manager the Search bar and press "Enter". Click Continue if necessary.
2.    In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the "Host Controller", click "Uninstall" and click "OK".
3.    Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and windows vista would reinstall all USB controllers automatically.
**Step 5:**Update the motherboard driver to the latest version.
**Note:**Please check with the motherboard manufacturer before installing the driver.
If the issue persists, contact the device manufacturer for more information:
http://ts.thrustmaster.com/eng/index.php
Thanks and Regards:
Ajay K
44 additional answers
    2011-12-26T17:19:05+00:00
    it fixes the bsod how ever the wheel remains uninstalled and doesnt work... so not rly a solution
    2011-12-26T19:22:19+00:00
    Your wheel must be connected. You must uninstall any drivers that appear in the device manager, even if there is a yellow icon. Plug your wheel and search devices again and installs the french drivers.
    2011-12-27T11:14:57+00:00
    marekblaszczyk answer fixed my problem, however the 2 little joysticks in the middle of my wheel do not work.
    win7 64b tested dirt 2 and dirt 3
    2011-12-29T10:19:46+00:00
    For players of Driver San Francisco. Here is a configured file of Thrustmaster FFW. Just unzip and copy to game folder.
    http://hotfile.com/dl/138828106/88af882/ffw\_driver\_sf\_config.rar.html
    Win 7 64bit SP1
