Printer problem - Items sent to print are not printing.
2010-09-04T04:54:31+00:00
I'm having problems with my printer.  If I send a document over to be printed it doesn't print?  There's no jam, the cartridges are full and there's  paper.  Help!
2011-07-01T21:28:02+00:00
Hi Bob,
Getting a test page out is good start, but there a few thing s you can try to get your printer fully working...
Microsoft provides a Fix It tool which will troubleshoot the printer for you, and might give some useful information on what might be causing an issue:
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-printer-problems
If you are getting prints out it sounds as though there isn't much wrong with the spools service, but keep an eye on it as sometimes a print job can throw the service out. You'll find it in Services.
Also, make sure you have the latest driver for the printer from the manufacturers website. You view what drivers you have already from Print Management, which you can find in Administrative Tools from the Control Panel.
Hope some this helps.
96 additional answers
    2011-06-29T15:12:50+00:00
    Hi Bob and Patty Edson,
    Since this post is almost a year old and to avoid confusion, I would recommend starting your own question so that the community can best focus on your specific issue.
    Thanks for using Microsoft Answers!
    2011-07-01T21:06:55+00:00
    2011-07-17T00:22:47+00:00
    i haveing problems with my printer  i have the icon on my dest top and when printing no responce  at all what can i do to fix this problem
    Regards
    Mr Gary Cook
    2011-08-24T17:17:13+00:00
    i need help with mine printer
