Printer problem - Items sent to print are not printing.
2010-09-04T04:54:31+00:00
I'm having problems with my printer.  If I send a document over to be printed it doesn't print?  There's no jam, the cartridges are full and there's  paper.  Help!
2011-07-01T21:28:02+00:00
Hi Bob,
Getting a test page out is good start, but there a few thing s you can try to get your printer fully working...
Microsoft provides a Fix It tool which will troubleshoot the printer for you, and might give some useful information on what might be causing an issue:
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-printer-problems
If you are getting prints out it sounds as though there isn't much wrong with the spools service, but keep an eye on it as sometimes a print job can throw the service out. You'll find it in Services.
Also, make sure you have the latest driver for the printer from the manufacturers website. You view what drivers you have already from Print Management, which you can find in Administrative Tools from the Control Panel.
Hope some this helps.
96 additional answers
    2013-01-27T22:25:20+00:00
    My problem has been solved. Thanks.
    2013-01-29T18:16:06+00:00
    my problem has been solved thankyou
    2013-01-31T06:13:47+00:00
    How is the computer connected to the printer?  USB, Network port, connection to another computer?
    Does printing generate an error or message stating that the print job failed?
    Have you verified you are using the latest drivers for the device?
    What print device is it just for reference.
    Alan Morris Windows Printing Team; Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/Default.aspx?adv=1
    WHAT ARE THE DRIVERS? ALL I HAVE IS THE CD'S THAT CAME WITH THE COMPUTER IS THIS WHAT YOU MEAN WHEN YOU SAY DRIVERS?
    2013-02-06T17:14:19+00:00
    My Printer is fixed
