How can I convert my USB memory stick from EXFAT to NTFS? It's not letting me format it to NTFS.
2009-12-31T04:38:56+00:00
original title: How to Convert EXFAT into NTFS...?????
Hi there,
I have bought 64GB USB Memory Stick. But I am not able to format this drive into NTFS file system. I have got Windows 7 operating system. It is only allowing me to formate it into EXFAT only. Because of non NTFS file system i am not able to copy bigger than 2GB file. Even sometimes if i copy the whole folder still nothing gets copy in it. Only the folder name.
I have tried different partition softwares to formate it into NTFS but still no louck atall. Even i tried to make partition of 8GB but still no luck.
So, is there any other way that i can formate my memory stick into NTFS file system.
Please help for this problem. I am looking for the solution since last 3 months.
Regards,
Palak Patel
    2014-01-20T15:46:23+00:00
    insert stick ... start... computer ... right click usb drive .... click format ... choose NFTS from options ............
    Your suggested solution does not work.
    2014-08-07T06:55:47+00:00
    hi i was just wondering if anyone has solved this problem? as i have the same problem
    2014-08-07T09:21:09+00:00
    2014-10-03T15:14:15+00:00
    mine is stuck on 2 %   help plz
    2014-10-03T15:17:01+00:00
    just bought a samsung m3 2tb 3.0. its on exfat and im trying to format onto ntfs but freeze my pc when i do so even on quick format....
