How can I convert my USB memory stick from EXFAT to NTFS? It's not letting me format it to NTFS.
2009-12-31T04:38:56+00:00
original title: How to Convert EXFAT into NTFS...?????
Hi there,
I have bought 64GB USB Memory Stick. But I am not able to format this drive into NTFS file system. I have got Windows 7 operating system. It is only allowing me to formate it into EXFAT only. Because of non NTFS file system i am not able to copy bigger than 2GB file. Even sometimes if i copy the whole folder still nothing gets copy in it. Only the folder name.
I have tried different partition softwares to formate it into NTFS but still no louck atall. Even i tried to make partition of 8GB but still no luck.
So, is there any other way that i can formate my memory stick into NTFS file system.
Please help for this problem. I am looking for the solution since last 3 months.
Regards,
Palak Patel
    2010-07-29T19:47:56+00:00
    Have you ran across and tried the HP USB Disk Storage Format Tool? I would try that. And I did notice this was Dec. 09
    2009-12-31T05:55:30+00:00
    start ... help and support... then type    file system      in search ... and take a look at #13 on the result list......
    2009-12-31T05:29:49+00:00
    2009-12-31T05:22:46+00:00
    As i said that i tried every sigle possibilities. Even i treid to change the policy as well. But still not working....
    2009-12-31T05:13:56+00:00
    insert stick ... start... computer ... right click usb drive .... click format ... choose NFTS from options ............
