ReadyBoost and sysmain
2010-01-23T23:31:44+00:00
I am trying to activate readyboost in windows 7 professional 64 bit. When I go to properties on the usb drive, it says ReadyBoost is not enabled because the service responsible for ReadyBoost (sysmain) has been turned off on this computer. An administrator can turn the sysmain back on. Please help.
2010-01-24T17:20:33+00:00
type services.msc into the startmenu search and launch the tool. Search the Superfetch entry and make a double click on it. Now change the start type to "automatic" and click on start. The service now starts and you should be able to use ReadyBoost.
Btw, you should never disbale Superfetch, it slows down your PC!
André
"A programmer is just a tool which converts caffeine into code" CLIP- Stellvertreter http://www.winvistaside.de/
54 additional answers
    2010-02-04T00:16:06+00:00
    Sorry, I overlooked your last answer. Do you have the correct value with \ ?
    2010-02-04T00:39:25+00:00
    Yes.
    Thanks for your help.
    2010-02-04T14:43:55+00:00
    please run ProcessMonitor (http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx) in background and try to start Superfetch. When you get the error message stop the trace in ProcessMonitor. Now filter all SUCCESS results out and look at the errors. Do you see more details which file is not found?
    André
    2010-02-05T04:37:13+00:00
    Reults when i attempt to startr superfetch
    8:34:59.1072314 PM svchost.exe 860 RegQueryValue HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Superfetch\MigratedData NAME NOT FOUND Length: 144
    8:34:59.1083091 PM svchost.exe 860 RegQueryValue HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Superfetch\DiskAssessment\VolumeSerialNumber NAME NOT FOUND Length: 144
    8:34:59.1650974 PM svchost.exe 860 RegQueryValue HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Superfetch\RebalancerFlags NAME NOT FOUND Length: 144
    8:34:59.1653223 PM svchost.exe 860 RegQueryValue HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Superfetch\PfPdData BUFFER OVERFLOW Length: 144
    8:34:59.1653521 PM svchost.exe 860 RegQueryValue HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Superfetch\PfPdData BUFFER OVERFLOW Length: 144
    8:34:59.2335862 PM svchost.exe 860 RegOpenKey HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Superfetch\Agents NAME NOT FOUND Desired Access: Read
    8:35:50.5788329 PM svchost.exe 860 RegQueryValue HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Superfetch\MigratedData NAME NOT FOUND Length: 144
    8:35:50.5788329 PM svchost.exe 860 RegQueryValue HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Superfetch\DiskAssessment\VolumeSerialNumber NAME NOT FOUND Length: 144
    8:35:50.6218258 PM svchost.exe 860 RegQueryValue HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Superfetch\RebalancerFlags NAME NOT FOUND Length: 144
    8:35:50.6275089 PM svchost.exe 860 RegQueryValue HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Superfetch\PfPdData BUFFER OVERFLOW Length: 144
    8:35:50.6790079 PM svchost.exe 860 RegOpenKey HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Superfetch\Agents NAME NOT FOUND Desired Access: Read
