ReadyBoost and sysmain
2010-01-23T23:31:44+00:00
I am trying to activate readyboost in windows 7 professional 64 bit. When I go to properties on the usb drive, it says ReadyBoost is not enabled because the service responsible for ReadyBoost (sysmain) has been turned off on this computer. An administrator can turn the sysmain back on. Please help.
2010-01-24T17:20:33+00:00
type services.msc into the startmenu search and launch the tool. Search the Superfetch entry and make a double click on it. Now change the start type to "automatic" and click on start. The service now starts and you should be able to use ReadyBoost.
Btw, you should never disbale Superfetch, it slows down your PC!
André
"A programmer is just a tool which converts caffeine into code" CLIP- Stellvertreter http://www.winvistaside.de/
54 additional answers
    2010-01-29T05:41:05+00:00
    Andre,
    Below is the log report that is generated each time I attempt to start superfetch.  This is a windows 7 upgrade from XP, I have attempted a clean reinstallation and it still gives me the same error.
    Thanks for your help.
    Joe.
    Log Name:      System
    Source:        Service Control Manager
    Date:          1/28/2010 9:35:00 PM
    Event ID:      7023
    Task Category: None
    Level:         Error
    Keywords:      Classic
    User:          N/A
    Computer:      JosephWixom-PC
    Description:
    The Superfetch service terminated with the following error:
    The system cannot find the file specified.
    Event Xml:
    <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
      <System>
        <Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
        <EventID Qualifiers="49152">7023</EventID>
        <Version>0</Version>
        <Level>2</Level>
        <Task>0</Task>
        <Opcode>0</Opcode>
        <Keywords>0x8080000000000000</Keywords>
        <TimeCreated SystemTime="2010-01-29T05:35:00.004882800Z" />
        <EventRecordID>13342</EventRecordID>
        <Correlation />
        <Execution ProcessID="552" ThreadID="2996" />
        <Channel>System</Channel>
        <Computer>JosephWixom-PC</Computer>
        <Security />
      </System>
      <EventData>
        <Data Name="param1">Superfetch</Data>
        <Data Name="param2">%%2</Data>
      </EventData>
    </Event>
    2010-01-29T14:20:57+00:00
    you get the following error:
    This means a file was not found. Can you please open Explorer and look inside your System32 folder and check that the file sysmain.dll is there?
    If not, open the cmd prompt (as administrator) and run sfc /scannow.
    André
    2010-01-30T18:36:23+00:00
    The file was not there yesterday, but it is there this morning.  The scannow ran and it said
    Windows resource protection did not find any integrity violations.  However, i cannot start superfetch.  I tried again in services, as well as in the command prompt by typing net start sysmain.  Each time it fails with a system error 2  The system cannot find the file specified.
    Thanks.
    2010-01-30T19:25:36+00:00
    start regedit and go to the following Key
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SysMain\Parameters
    What is the value of ServiceDll ?
    André
