INTERNAL_POWER_ERROR (a0)
2009-08-25T20:50:39+00:00
My computer is crashing with the following error: “INTERNAL_POWER_ERROR (a0) The power policy manager experienced a fatal error.” What can I do about this?
2009-08-25T20:55:56+00:00
This error is caused by the hibernation file size being is too small for the current memory requirements of the computer. To fix this problem, increase the size of the hibernation file by following these steps:
  1. Click the Start button.
  2. In the search box, type command prompt.
  3. In the list of results, right-click Command Prompt, and then click Run as administrator.
  4. In the Command Prompt window type:
powercfg /hibernate /size <size%>
where <size%> equals the size of the hibernation file in percentage of total physical memory.
The default size is 75% and can be increased to 100% with:
powercfg /hibernate /size 100
42 additional answers
    2016-06-14T23:12:49+00:00
    ok this goes for u and everyone else here
    fill out this form for amd
    dont worry if u dont know all the answers to this,, the main things u need to give is what graphics card u got
    if u dont know that then just give what make and model pc/laptop u have and they can go from there and explain exactly what happend and what windows u are running
    heres the website
    CLICK ON THIS TO GO TO AMDS ERROR REPORTING PAGE
    if the click dont work then copy paste this into your browsers address bar
    http://www.amdsurveys.com/se.ashx?s=5A1E27D23A3DE979
    if u duno how to do that then pay someone to fix your pc
    2016-06-15T00:15:14+00:00
    In a crunch I simply went into Device Mgr. and disabled the driver.  It'll slow down your laptop fan shortly after, and a reboot isn't necessary.  Eh I guess I'm lazier now these days and take the easy way out.  Eh didn't feel like meshing with AMDs website.  ;-)
