How to a change my printer default setting from color to grayscale permanently.
2010-01-23T20:06:16+00:00
How do I  change my printer default setting from color to grayscale on a permanent basis.  Since I mostly print in greyscale, I want this as the default and then can change manually, as needed, when I want to print in color.  Thanks
2010-01-23T20:43:30+00:00
Go to the Start Orb and select Devices and Printers. Right click on your printer and select Printing Preferences. Here you should be able to select gray scale under Color and save it..
49 additional answers
    2016-04-25T17:31:39+00:00
    In Windows 10, right-clicking on the printer does not do anything.
    2016-06-23T03:13:04+00:00
    I am having the same issue.  This solution does not work for Windows 10.  You cannot right click on the printer in the settings menu.  Nothing happens. This used to be very simple in previous Windows versions. Help please.
    2016-06-23T03:33:19+00:00
    That's the ticket.  Worked like a charm.  Thanks!!
    2016-08-11T20:10:07+00:00
    That worked for me as well!
