Can't format USB drive in NTFS format
2010-06-07T17:17:06+00:00
Can't format USB drive in windows 7
I recently bought a kingston 64GBUSB flash drive.  This works fine but I need to  format it in NTFS and windows format says it can't complete the format. Can anyone help?  answer here or at *** Email address is removed for privacy ***.  Thank ahead of time.
2010-06-08T16:13:23+00:00
By default, Windows provides the option to format a USB flash drive with FAT or FAT32 file systems only, but not with  NTFS (New Technology****File System.)
The reason behind this is that there are some disadvantages of NTFS usage in this case. First of all, the speed of saving on the flash drive decreases (but the speed of reading data from the drive is the same), and you have to be more careful to always remove the USB flash drive safely.
However, you can still format the Flash Drive in the NTFS format. Follow these steps for the same.
1.      Insert the USB flash drive into the USB port.
2.      Click Start, type devmgmt.msc in the Search textbox and press  Enter.
3.      Find Disk Drives and expand it.
4.      Find the USB flash drive you want to format, and double-click it. It opens the  Properties dialog box.
5.      Click Policies tab.
6.      By default, the  Optimize for quick removal option selected, switch it to Optimize for performance and then pressOK.
7.      Now open  Computer. Right click on the USB Flash Drive and select Format. The Format dialog box now appears.
8.      Select NTFS in the File System field.
9.      Press Start and wait while the process will be completed.
10.   Now your USB Flash Drive is formatted with NTFS format.
Regards,
Syed N – Microsoft Support
50 additional answers
    2016-08-08T22:16:47+00:00
    OMG, didn't even think to partition it! (Obviously)
    Thanks Mark 😀
    2016-08-25T23:07:08+00:00
    Your best chance is low level format, your hard disk has bad sectors thats why it can not be formated.
    cristal disk info could help  you findout if there are bad sectors
    http://crystalmark.info/software/CrystalDiskInfo/index-e.html
    low level format
    https://www.google.ca/search?q=low+level+format&ie=utf-8&oe=utf-8&client=firefox-b-ab&gfe\_rd=cr&ei=kik-V5-yBOzE8gfp2bjQAw
    regards
    2016-09-23T15:08:02+00:00
    I have the same issue and have tried 3 times now to change the eFAT32 to NTFS but it fails each time. I have done the procedure mentioned above and just the normal one from This Computer (using Win 10) format drive etc and it fails on that too. I only wanted to be able to convert the 128GB usb pen drive so I could back up my operating system to the pen drive and stick in my desk for possible use in the future.
    Has anyone successfully done this task?
    Steve
    2016-11-10T23:31:08+00:00
    I have a Kingston data traveler USB 3.0, and when i try to format it to ntfs, it says that windows  was unable to complete the formatting, It's not write protected, and I optimized it for preformance, and it still doesn't do anything. PLEASE HELP
