Can't format USB drive in NTFS format
2010-06-07T17:17:06+00:00
Can't format USB drive in windows 7
I recently bought a kingston 64GBUSB flash drive.  This works fine but I need to  format it in NTFS and windows format says it can't complete the format. Can anyone help?  answer here or at *** Email address is removed for privacy ***.  Thank ahead of time.
2010-06-08T16:13:23+00:00
By default, Windows provides the option to format a USB flash drive with FAT or FAT32 file systems only, but not with  NTFS (New Technology****File System.)
The reason behind this is that there are some disadvantages of NTFS usage in this case. First of all, the speed of saving on the flash drive decreases (but the speed of reading data from the drive is the same), and you have to be more careful to always remove the USB flash drive safely.
However, you can still format the Flash Drive in the NTFS format. Follow these steps for the same.
1.      Insert the USB flash drive into the USB port.
2.      Click Start, type devmgmt.msc in the Search textbox and press  Enter.
3.      Find Disk Drives and expand it.
4.      Find the USB flash drive you want to format, and double-click it. It opens the  Properties dialog box.
5.      Click Policies tab.
6.      By default, the  Optimize for quick removal option selected, switch it to Optimize for performance and then pressOK.
7.      Now open  Computer. Right click on the USB Flash Drive and select Format. The Format dialog box now appears.
8.      Select NTFS in the File System field.
9.      Press Start and wait while the process will be completed.
10.   Now your USB Flash Drive is formatted with NTFS format.
Regards,
Syed N – Microsoft Support
50 additional answers
    2016-01-12T03:16:03+00:00
    Gina,
    Try resetting using diskpart.  It's worked for me many times.
    http://www.supertalent.com/datasheets/Resetting%20USB%20drive%20using%20Windows%20Diskpart-V1.pdf
    2016-05-08T15:22:43+00:00
    Thank you thats to correct answer!
    you can use this program to find out exactly the size: RMPrepUSB_Portable_v2.1.730
    I bought from ebay 6 pieces 3 defective, one was loaded with autorun virus. follow the link
    https://www.virustotal.com/en/file/c81b87d806950f4f4cd013b5157587bd707a5ba883b039ca519a8306c5b771a3/analysis/1459355934/
    the 64 gig actual size is 16 gig and reporting 64
    correcting the size fixed the format problem. The big problem is if its formatted with fat32 or exfat it allow you to copy files as much as the fake size once you copy more than the size all files will be corrupted and gone. they compromising customers files.
    more info on this
    http://www.ebay.com/gds/BEWARE-of-FAKE-128GB-256GB-USB-Flash-Drives-on-eBayeBay-/10000000046978438/g.html
    http://www.ebay.com/gds/All-About-Fake-Flash-Drives-2013-/10000000177553258/g.html
    Many thanks for this info. I'll never buy from ebay!
    2016-06-26T10:12:52+00:00
    This does not work for me
    When i tried this, it says "Windows can not format the disk"
    i have an 1 tb hard drive which is infected by viruses
    at first i formatted it in NTFS type with complete format, then after completing the half of the process it says "windows is unable to format the disk" .
    then i formatted it with ExFAT and it is successfully formatted
    but now when i tried again it to convert to NTFS it is not working and again says window is unable to format the disk...
    Help please!!!
    2016-08-08T20:12:25+00:00
    This is the best solution! Installed the program and in 1 or 2 minutes a formatted NTFS partion 29GB.
    Was reading forums for a hour and found this post, thanks!
    Bad MS! Disk Management is probably to basic for these kind of actions.
