Can't format USB drive in NTFS format
2010-06-07T17:17:06+00:00
Can't format USB drive in windows 7
I recently bought a kingston 64GBUSB flash drive.  This works fine but I need to  format it in NTFS and windows format says it can't complete the format. Can anyone help?  answer here or at *** Email address is removed for privacy ***.  Thank ahead of time.
2010-06-08T16:13:23+00:00
By default, Windows provides the option to format a USB flash drive with FAT or FAT32 file systems only, but not with  NTFS (New Technology****File System.)
The reason behind this is that there are some disadvantages of NTFS usage in this case. First of all, the speed of saving on the flash drive decreases (but the speed of reading data from the drive is the same), and you have to be more careful to always remove the USB flash drive safely.
However, you can still format the Flash Drive in the NTFS format. Follow these steps for the same.
1.      Insert the USB flash drive into the USB port.
2.      Click Start, type devmgmt.msc in the Search textbox and press  Enter.
3.      Find Disk Drives and expand it.
4.      Find the USB flash drive you want to format, and double-click it. It opens the  Properties dialog box.
5.      Click Policies tab.
6.      By default, the  Optimize for quick removal option selected, switch it to Optimize for performance and then pressOK.
7.      Now open  Computer. Right click on the USB Flash Drive and select Format. The Format dialog box now appears.
8.      Select NTFS in the File System field.
9.      Press Start and wait while the process will be completed.
10.   Now your USB Flash Drive is formatted with NTFS format.
Regards,
Syed N – Microsoft Support
50 additional answers
    2015-10-25T14:49:55+00:00
    This is so simple
    When the format box comes up change the File system to NTFS and importantly change the Allocation unit size to Default allocation size and no need to untick the quick format and you have an NTFS formatted memory stick to write to.
  2. Deleted
    2015-11-08T23:02:52+00:00
    Regards,
    Well, i have the same problem. Only im running windows 10. but whenever, even after your tutorial, it says windows cannot complete the format, thus leaving the USB corrupted, though i know the solution to corrupted USB's. but i still need the solution to the NTFS format.
    2016-01-12T02:56:20+00:00
    Hi Syed,
    I just tried this now...is there any reason why I still can't format to NTFS?
    I've tried both the quick format option and the normal and both come up with the message that this disk can't be formatted?
    Any further help would be appreciated.
    Regards,
    Gina
