Can't format USB drive in NTFS format
2010-06-07T17:17:06+00:00
Can't format USB drive in windows 7
I recently bought a kingston 64GBUSB flash drive.  This works fine but I need to  format it in NTFS and windows format says it can't complete the format. Can anyone help?  answer here or at *** Email address is removed for privacy ***.  Thank ahead of time.
2010-06-08T16:13:23+00:00
By default, Windows provides the option to format a USB flash drive with FAT or FAT32 file systems only, but not with  NTFS (New Technology****File System.)
The reason behind this is that there are some disadvantages of NTFS usage in this case. First of all, the speed of saving on the flash drive decreases (but the speed of reading data from the drive is the same), and you have to be more careful to always remove the USB flash drive safely.
However, you can still format the Flash Drive in the NTFS format. Follow these steps for the same.
1.      Insert the USB flash drive into the USB port.
2.      Click Start, type devmgmt.msc in the Search textbox and press  Enter.
3.      Find Disk Drives and expand it.
4.      Find the USB flash drive you want to format, and double-click it. It opens the  Properties dialog box.
5.      Click Policies tab.
6.      By default, the  Optimize for quick removal option selected, switch it to Optimize for performance and then pressOK.
7.      Now open  Computer. Right click on the USB Flash Drive and select Format. The Format dialog box now appears.
8.      Select NTFS in the File System field.
9.      Press Start and wait while the process will be completed.
10.   Now your USB Flash Drive is formatted with NTFS format.
Regards,
Syed N – Microsoft Support
50 additional answers
    2013-06-29T09:11:33+00:00
    Dear Syed N
    After adopting the mentioned procedure window giving the message that :Window was unable to complete the format" as i have installed Window 7. Kindly help me because my usb is giving space 0 media not found brand kingston 2 gb.
    Regards
    2013-08-02T22:31:56+00:00
    I also had issues with trying to format a USB stick to NTFS and it failed.  The drive then would show up if I unplugged it and plugged back in, went into device manager under disk drives, and right clicked USB drive and scanned for hardware changes.  But the drive then showed up in My Computer with 0 capacity and I could not even reformat it back to FAT32.
    I found a utility from HP that formats USB drives and was able to use it to format the drive to FAT32 and now it works again.  But still, can't get NTFS out of it.
    http://www.softpedia.com/get/System/Hard-Disk-Utils/HP-USB-Disk-Storage-Format-Tool.shtml
    2014-02-09T19:37:04+00:00
    Do I do the same for 8.1 windows?? I have the same problem but I have 8.1 windows !!
    2014-04-10T01:42:53+00:00
    Is your Windows computer compatible with NTFS format?
    If it is not, that absolutely explains why you cannot format this new USB flash drive on your computer into NTFS format. So, if you really need format it to NTFS format, you should do it on another computer that supports NTFS format.
