Can't format USB drive in NTFS format
2010-06-07T17:17:06+00:00
Can't format USB drive in windows 7
I recently bought a kingston 64GBUSB flash drive.  This works fine but I need to  format it in NTFS and windows format says it can't complete the format. Can anyone help?  answer here or at *** Email address is removed for privacy ***.  Thank ahead of time.
2010-06-08T16:13:23+00:00
By default, Windows provides the option to format a USB flash drive with FAT or FAT32 file systems only, but not with  NTFS (New Technology****File System.)
The reason behind this is that there are some disadvantages of NTFS usage in this case. First of all, the speed of saving on the flash drive decreases (but the speed of reading data from the drive is the same), and you have to be more careful to always remove the USB flash drive safely.
However, you can still format the Flash Drive in the NTFS format. Follow these steps for the same.
1.      Insert the USB flash drive into the USB port.
2.      Click Start, type devmgmt.msc in the Search textbox and press  Enter.
3.      Find Disk Drives and expand it.
4.      Find the USB flash drive you want to format, and double-click it. It opens the  Properties dialog box.
5.      Click Policies tab.
6.      By default, the  Optimize for quick removal option selected, switch it to Optimize for performance and then pressOK.
7.      Now open  Computer. Right click on the USB Flash Drive and select Format. The Format dialog box now appears.
8.      Select NTFS in the File System field.
9.      Press Start and wait while the process will be completed.
10.   Now your USB Flash Drive is formatted with NTFS format.
Regards,
Syed N – Microsoft Support
50 additional answers
    2018-04-13T01:35:27+00:00
    I upgraded to windows 10 back when you could do it over the internet.  Now however, I find lots of my things are still windows 7.  ie; the back up and many other things,  So, when you give instructions to change my SD card to NTFS I have to ad lib a bit to try to make it fit my half windows 7 & half windows 10.  I am still not able to format my Kingston 64GB as NTFS.  Can you help me?
    2018-07-04T09:04:17+00:00
    I have recently bought the Kingston HyperX Savage 128GB flash drive, which comes with exFAT. I have tried to format it to NTFS using these instructions, but when I in step 7 open 'computer', my USB flash drive doesn't appear - only the one on my pc.
    Somebody in the comments mentioned to safely remove the flash drive after step 6 and then plug it in again before step 7. I also did this, but no luck.
    What to do?
