Can't format USB drive in NTFS format
2010-06-07T17:17:06+00:00
Can't format USB drive in windows 7
I recently bought a kingston 64GBUSB flash drive.  This works fine but I need to  format it in NTFS and windows format says it can't complete the format. Can anyone help?  answer here or at *** Email address is removed for privacy ***.  Thank ahead of time.
2010-06-08T16:13:23+00:00
By default, Windows provides the option to format a USB flash drive with FAT or FAT32 file systems only, but not with  NTFS (New Technology****File System.)
The reason behind this is that there are some disadvantages of NTFS usage in this case. First of all, the speed of saving on the flash drive decreases (but the speed of reading data from the drive is the same), and you have to be more careful to always remove the USB flash drive safely.
However, you can still format the Flash Drive in the NTFS format. Follow these steps for the same.
1.      Insert the USB flash drive into the USB port.
2.      Click Start, type devmgmt.msc in the Search textbox and press  Enter.
3.      Find Disk Drives and expand it.
4.      Find the USB flash drive you want to format, and double-click it. It opens the  Properties dialog box.
5.      Click Policies tab.
6.      By default, the  Optimize for quick removal option selected, switch it to Optimize for performance and then pressOK.
7.      Now open  Computer. Right click on the USB Flash Drive and select Format. The Format dialog box now appears.
8.      Select NTFS in the File System field.
9.      Press Start and wait while the process will be completed.
10.   Now your USB Flash Drive is formatted with NTFS format.
Regards,
Syed N – Microsoft Support
50 additional answers
    2017-03-27T16:45:18+00:00
    OK. Now let's use the administrator's method:
    1. While on the desktop, press the space bar and type the letters cmd. Do not press Enter.
    2. Right-click cmd.exe up the top, then left-click Run as administrator. This will open a black window.
    3. Type the commands you see below in italics and press Enter after each.
    D:>diskpart
    DISKPART> select disk 1
    Disk 1 is now the selected disk.
    DISKPART> detail disk
    TOSHIBA MQ01ABD100 USB Device
      Volume ###  Ltr  Label        Fs     Type        Size     Status     Info
      Volume 6     G   RecoverySma  NTFS   Partition    450 MB  Healthy
    Before continuing, make absolutely sure that this is your flash disk! If it is not, try "select disk 2" etc.
    DISKPART> clean
    DiskPart succeeded in cleaning the disk.
    DISKPART> create partition primary
    DiskPart succeeded in creating the specified partition.
    * Volume 6                      RAW    Partition    931 GB  Healthy
    DISKPART> select volume 6
    Volume 6 is the selected volume.
    DISKPART> format FS=NTFS Label="Some Label"  quick
    DiskPart successfully formatted the volume.
    DISKPART> assign letter=G
    DiskPart successfully assigned the drive letter or mount point.
    DISKPART> exit
    exit
    2017-06-10T04:01:39+00:00
    This is the best solution! Installed the program and in 1 or 2 minutes a formatted NTFS partion 29GB.
    Was reading forums for a hour and found this post, thanks!
    Bad MS! Disk Management is probably to basic for these kind of actions.
    You are putting your files on risk if windows could not format it to NTFS that mean your drive has fake capacity, I have 6 of these bought from ebay all FAKE, the 32 gig might be only 16 or 8.
    I received my money back and I am using the drives but aware of the real size.
    Windows will not format coz it can not determent the actual size.
    Read this
    http://www.ebay.com/gds/All-About-Fake-Flash-Drives-2013-/10000000177553258/g.html
    And this
    http://www.ebay.ca/cln/tnimitz0/cheap-512gb-fraud-fake-capacity-usb-flash-drives/167592666015
    2017-06-15T03:14:13+00:00
    it doesn't work for me brah
    2017-06-24T04:49:17+00:00
    i try those step i got same problem
