Gateway laptop: Plugged in, not charging
2009-04-13T05:04:39+00:00
I bought my Gateway laptop in January. Randomly last night it said "Plugged in, not charging" on the battery meter. I know this is NOT an issue with Gateway because I have googled this issue and the common problems seems to be Vista. I tried following these four steps that some have claimed work
1.
Click Start and type device in the search field, then select Device Manager .
2.
Expand the Batteries category.
3.
Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4.
On the Device Manager taskbar, click Scan for hardware changes .
Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the battery is charging."
but I didn't have much luck with that at all. I really need someone to tell me how to fix this problem because the fact that this has clearly been a big issue for Vista users everywhere over the past 2 or so years is completely unacceptable and honestly I'm getting really annoyed with the issue. So please help me with this Vista problem and I know for a fact its not a problem with Gateway because it's a practically new computer.
2010-07-26T19:15:37+00:00
Here is what I've done and it worked for me:
first 2 steps as you have written
step 3: instead of uninstall, I've selected disable. I've waited for 2-3 minutes and enabled is again.
Once I've enabled, it started to charge.
I can't guarantee it will work for everyone, but it worked for me. Give a try and let me know if it worked.
75 additional answers
    2011-02-24T14:53:29+00:00
    Click on the below link to update the BIOS:
    http://support.gateway.com/support/drivers/getFile.asp?id=24424&dscr=Gateway%20MC73,%20MC78,%20MD73%20and%20MD78%20BIOS%20Version%209911a%20for%20Windows%20Vista&uid=297486028
    Please follow the below steps to install BIOS:
    • Download the file and unzip its contents to the computer.
    • Run the BIOS update application from the Windows folder
    • Follow the prompts to install the update to the BIOS.
    After installing the BIOS file:
    • Shutdown the computer.
    • Remove the battery for 30 seconds, then reinstall the battery
    • Reboot the computer and press F2 to go into the BIOS Setup Utility.
    • Press F9 to load default configuration.
    • Press F10 to save configuration and exit.
    Worked for my Gateway MD7333u.  Got this answer from gateway.
    2011-04-03T01:48:02+00:00
    You need to disable your battery meter, restart your computer and then enable the meter and it should work fine, worked for me with the same model
    2011-06-04T19:22:31+00:00
    I had the same problem on Gateway laptop (a few years old) running Windows XP. I tried the steps above, except instead of uninstalling I just disabled the ACPI compliant driver. This didn't work. So instead I:
    Shut the computer down.
    Removed the battery and waited 2-3 minutes. Replaced Battery.
    Powered laptop back on and everything is back to normal.
    As soon as I took the battery out, the red light on the front went away and when I put it back in it went back to the pink/purple light so I knew it was going to work!
    2011-06-16T22:09:05+00:00
    Worked great.  Thank you
