Gateway laptop: Plugged in, not charging
2009-04-13T05:04:39+00:00
I bought my Gateway laptop in January. Randomly last night it said "Plugged in, not charging" on the battery meter. I know this is NOT an issue with Gateway because I have googled this issue and the common problems seems to be Vista. I tried following these four steps that some have claimed work
1.
Click Start and type device in the search field, then select Device Manager .
2.
Expand the Batteries category.
3.
Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4.
On the Device Manager taskbar, click Scan for hardware changes .
Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the battery is charging."
but I didn't have much luck with that at all. I really need someone to tell me how to fix this problem because the fact that this has clearly been a big issue for Vista users everywhere over the past 2 or so years is completely unacceptable and honestly I'm getting really annoyed with the issue. So please help me with this Vista problem and I know for a fact its not a problem with Gateway because it's a practically new computer.
2010-07-26T19:15:37+00:00
Here is what I've done and it worked for me:
first 2 steps as you have written
step 3: instead of uninstall, I've selected disable. I've waited for 2-3 minutes and enabled is again.
Once I've enabled, it started to charge.
I can't guarantee it will work for everyone, but it worked for me. Give a try and let me know if it worked.
75 additional answers
    2010-09-05T18:33:48+00:00
    After 2 days of researching, I finally fixed this myself. My Gateway Md78 is only a yr n a half old, and about 3 months ago I started getting the "plugged in, not charging" ____. I thought it was because the battery is dying, so I just bought a new battery. Same problem was happening. Then I read somewhere else to uninstall the Microsoft ACPI Compliant Control Method Battery. So, here's what I did when I put a bunch of ____ together:
    Shut down Computer. unplug AC. Take out battery. Plug in AC. Start up computer. Disable Microsoft ACPI CC Method Battery (I really didn't see the point in uninstalling it...). Shut down computer. Unplug AC. Insert battery. Plug in AC. Turn on. Enable Microsoft ACPI. Then it was working
    I did the whole shut down, unplug, plug, scenario because it was suggested all over the place, and sometimes with the process of disabling the program. Whether that worked is what worked, or just disabled/enabling it, I don't know, but either way, it worked. And Now here I am with 2 perfectly fine batteries and I'm expecting this problem to happen again.
    I also noticed that even though it was saying the battery was 0 power and not charging, when I unplugged the AC and let the computer run its course, it lasted 2 hours. So frankly, it wasn't the battery at all and they were charging/charged despite the indicator.
    2010-09-08T15:40:25+00:00
    I have researched for quite a while about this problem and the closest i have ever gotten to fixing it is with your suggestion. But it really didnt do much since my computer only picked 2% of charging and went back to not charging. I wonder wat percentage of charge you gained before everything went back to the status quo.
    2010-09-08T19:07:04+00:00
    I actually gained full power after I solved this... with the first/original battery. Mainly because I was noticing the batteries weren't dead at all, it was the computer's problem. Today, it says 97% power, plugged in not charging. But if I unplug it for a while and plug it back in, it will start charging. If you're didn't charge, it might be a dead/dying battery. When I was researching, i also read that some people had bad AC adapters, which weren't able to use enough voltage to charge the battery after a while, so you should make sure the voltage is correct for your computer/battery ... cause I also heard Windows Vista uses a ton of power and eats away at it. If the above didn't work for you, I'd suggest getting a new battery and going from there.
    2010-09-09T00:47:25+00:00
    Pandaundercover, I want to begin by appreciating you so much in finding time to reply to my post. Thank you. Now in getting back to the problem, i would say that i tried using your method( one you posted) and actually gained 4% for the 2 times i did do it. I rose from 76% to 78% and then from 78% to 80%. Now assuming that i had continue doing this i would have probably ended up with 100%( i highly doubt it). My problem is, when it says plugged in, not charging, my gateway computer battery light goes red and when you unplug the ac adapter the battery meter show me i have 0% of battery remaining but it does not shut down. And after i leave it on for a while and plug back the ac adapter, it says 0% available, plugged in, not charging. I unplug the ac adapter again, and same thing happens as earlier. It cannot be the battery, that one am sure. Still researching though..am closer to it. I can feel it
