Gateway laptop: Plugged in, not charging
2009-04-13T05:04:39+00:00
I bought my Gateway laptop in January. Randomly last night it said "Plugged in, not charging" on the battery meter. I know this is NOT an issue with Gateway because I have googled this issue and the common problems seems to be Vista. I tried following these four steps that some have claimed work
1.
Click Start and type device in the search field, then select Device Manager .
2.
Expand the Batteries category.
3.
Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4.
On the Device Manager taskbar, click Scan for hardware changes .
Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the battery is charging."
but I didn't have much luck with that at all. I really need someone to tell me how to fix this problem because the fact that this has clearly been a big issue for Vista users everywhere over the past 2 or so years is completely unacceptable and honestly I'm getting really annoyed with the issue. So please help me with this Vista problem and I know for a fact its not a problem with Gateway because it's a practically new computer.
2010-07-26T19:15:37+00:00
Here is what I've done and it worked for me:
first 2 steps as you have written
step 3: instead of uninstall, I've selected disable. I've waited for 2-3 minutes and enabled is again.
Once I've enabled, it started to charge.
I can't guarantee it will work for everyone, but it worked for me. Give a try and let me know if it worked.
75 additional answers
    2014-07-31T01:06:31+00:00
    I've been baffled with this plugged in and charging since last friday.  My gateway nv79 laptop told me my battery needed changing.  so since it was 3 yrs old, no shame in changing it.
    Bought a new one saturday morning.  charged and decharged fine all weekend.  Monday morning it was fine.  Monday before dinner, the problem came back.  The store exchanged the battery this evening.  Now tonight after an hour, the problem has returned.  I get a red X - no battery detected, then I get plugged in and charging.
    I am having no luck what so ever with this.  as I type this the red X comes and goes, and comes back.
    I tried disabling the microsoft ACPI and nothing has changed for me.
    I just want to cry.
    dar
    2015-08-29T00:42:02+00:00
    I have the same issue and have tried all of these suggestions multiple times but...i switched to Windows 7 and still have the same issue. Anyone know how to diagnose the adapter or motherboard?
    2016-03-19T04:06:30+00:00
    Windows 10 is the same thing. Did the ACPI thing 2 different ways with disabling and uninstalling. Now I can't get either one to go back. And I'm still not charging, PLUS now I have 2 dead batteries instead of one. H E L P  someone
    2016-03-19T04:16:24+00:00
    Tried your system with the disable, but after I put it all back together, there was no enable to get it back. Tried the other guys with the uninstall, but again there was no reinstall. So great! Now I have 2 posted deletes that I can't get back, I'm still not charging, AND now I'm the proud owner of two worthless batteries (one of them is brand spanking new yesterday) that aren't doing me a blessed thing. Thanks
