Gateway laptop: Plugged in, not charging
2009-04-13T05:04:39+00:00
I bought my Gateway laptop in January. Randomly last night it said "Plugged in, not charging" on the battery meter. I know this is NOT an issue with Gateway because I have googled this issue and the common problems seems to be Vista. I tried following these four steps that some have claimed work
1.
Click Start and type device in the search field, then select Device Manager .
2.
Expand the Batteries category.
3.
Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4.
On the Device Manager taskbar, click Scan for hardware changes .
Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the battery is charging."
but I didn't have much luck with that at all. I really need someone to tell me how to fix this problem because the fact that this has clearly been a big issue for Vista users everywhere over the past 2 or so years is completely unacceptable and honestly I'm getting really annoyed with the issue. So please help me with this Vista problem and I know for a fact its not a problem with Gateway because it's a practically new computer.
2010-07-26T19:15:37+00:00
Here is what I've done and it worked for me:
first 2 steps as you have written
step 3: instead of uninstall, I've selected disable. I've waited for 2-3 minutes and enabled is again.
Once I've enabled, it started to charge.
I can't guarantee it will work for everyone, but it worked for me. Give a try and let me know if it worked.
75 additional answers
    2011-06-18T13:07:20+00:00
    thats all i did. take out battery reinstall battery then turn laptop back on.workes every time.sometime down the road it will happen again just remember to remove battery then reinstall.
    2011-07-11T16:12:32+00:00
    you were spot on right---THANK YOU!!!
    2011-07-13T13:23:02+00:00
    UPDATE!! This worked for my laptop and it was so easy..
    Go ahead and uninstall the battery like before.  Shut down your computer and take the battery out. (On the opposite side of the computer, very easy.) Wait 3 minutes, put battery back in laptop, turn on computer with chord plugged in.  When you sign in, there ya go! Battery plugged in, charging. Let me know if it works for you. hope it helps
    2011-08-07T16:51:21+00:00
    It's not just Vista... I'm currently having it on a Gateway which is running Windows 7.  I agree that it doesn't appear to be hardware, and I've been doing computer support since 1986.  I've noticed two key things that lead me to believe it's an OS issue and that is the fact that:
    1. Unplugging the power and plugging it back in, causes it to start working briefly... the icon will show the charging symbol for a minute or so and often, it will gain 1% of displayed power.
    2. I unplugged my laptop and put it away for a week (I only use this laptop when I'm away from home or using it for timing and scoring during a NASCAR race) and when I powered it up again, it showed 6% MORE battery power than it did when I shut it down.  Now, we all know batteries cannot possibly GAIN power while not connected to a charger so it must be an issue with the way Windows is measuring/displaying this info.
    Finally, it is clearly evident that there have been a number of folks who have run into this issue and managed to fix it by either uninstalling, or disabling the driver and then re-installing/enabling the driver.  If it's hardware, you can't fix it with software!
