Print Spooler stops after trying to print a PDF file and it will not restart.
2010-09-08T17:02:07+00:00
Original Title: Print Spooler![](http://i4.social.answers.microsoft.com/Forums/resources/images/trans.gif?cver=2.13.0068.4)
The print spooler stops after trying to print a PDF file and it will not restart.  The only way I have been able to print again is to do a System Recovery.  When I try to print a PDF file again the print spooler does the same thing.
Any help is appreciated.
Thanx,
2010-09-09T05:04:00+00:00
Hi binofelix,
·        What happens when you try to restart print spooler when it stops? How are you trying to restart the print spooler service? Do you get any error message or any error code?
Try the steps below and check if it helps:
Step 1:
When the print spooler service stops, try restarting it and check if it helps. If you have already tried the steps then ignore Step 1.
a. Click Start and then type "services" (without quotes) in the Start Search box.
b. In the results area, right-click services, and then click “Run as administrator”.
You will be prompted to type the password for an administrator account. Click Continue if you are the administrator or type the administrator password. Then, click Continue.
c. In Services Window locate the service “Print Spooler” and double click on it.
d. Make sure that the Startup type is set to “Automatic” and the Service status is “Started”.
Step 2:
Try running the printer troubleshooter and check if it helps.
Open the Printer troubleshooter
Step 3:
Try the following Microsoft Fixit and check if it helps.
Fix printing problems by resetting the print spooler (Applicable to Windows 7)
Also, have a look at the following article links:
Why can't I print?
Printer problems in Windows
****Hope this helps. Let us know if you need further assistance.
Thanks and Regards, Santosh Y – Microsoft Support
Visit our **Microsoft Answers Feedback**Forum and let us know what you think.
[If this post was helpful, please click the "Vote As Helpful" (green triangle) button. If it helps in resolving your issue, click "Propose As Answer" or "Mark As Answer" button. By proposing/marking a post as Answered, or Helpful you help others find the answer faster.
2014-09-18T08:18:36+00:00
Hello Joe,
Thank you for your reply.
I would suggest you to rebuild print spooler service and check if it helps. Please follow these steps:
a. Press Windows + R keys, type notepad in run window and press Enter.
b. In notepad, copy and paste the following:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Spooler]
"DisplayName"="@%systemroot%\system32\spoolsv.exe,-1"
"Group"="SpoolerGroup"
"ImagePath"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,\
  74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,\
  00,70,00,6f,00,6f,00,6c,00,73,00,76,00,2e,00,65,00,78,00,65,00,00,00
"Description"="@%systemroot%\system32\spoolsv.exe,-2"
"ObjectName"="LocalSystem"
"ErrorControl"=dword:00000001
"Start"=dword:00000002
"Type"=dword:00000110
"DependOnService"=hex(7):52,00,50,00,43,00,53,00,53,00,00,00,68,00,74,00,74,00,\
  70,00,00,00,00,00
"ServiceSidType"=dword:00000001
"RequiredPrivileges"=hex(7):53,00,65,00,54,00,63,00,62,00,50,00,72,00,69,00,76,\
  00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,49,00,6d,00,70,00,65,00,\
  72,00,73,00,6f,00,6e,00,61,00,74,00,65,00,50,00,72,00,69,00,76,00,69,00,6c,\
  00,65,00,67,00,65,00,00,00,53,00,65,00,41,00,75,00,64,00,69,00,74,00,50,00,\
  72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,43,00,68,\
  00,61,00,6e,00,67,00,65,00,4e,00,6f,00,74,00,69,00,66,00,79,00,50,00,72,00,\
  69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,4c,00,6f,00,61,\
  00,64,00,44,00,72,00,69,00,76,00,65,00,72,00,50,00,72,00,69,00,76,00,69,00,\
  6c,00,65,00,67,00,65,00,00,00,53,00,65,00,41,00,73,00,73,00,69,00,67,00,6e,\
  00,50,00,72,00,69,00,6d,00,61,00,72,00,79,00,54,00,6f,00,6b,00,65,00,6e,00,\
  50,00,72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,00,00
"FailureActions"=hex:80,51,01,00,00,00,00,00,00,00,00,00,03,00,00,00,14,00,00,\
  00,01,00,00,00,60,ea,00,00,01,00,00,00,60,ea,00,00,00,00,00,00,00,00,00,00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Spooler\Performance]
"Close"="PerfClose"
"Collect"="PerfCollect"
"Collect Timeout"=dword:000007d0
"Library"="winspool.drv"
"Object List"="1450"
"Open"="PerfOpen"
"Open Timeout"=dword:00000fa0
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Spooler\Security]
"Security"=hex:01,00,14,80,78,00,00,00,84,00,00,00,14,00,00,00,30,00,00,00,02,\
  00,1c,00,01,00,00,00,02,80,14,00,ff,01,0f,00,01,01,00,00,00,00,00,01,00,00,\
  00,00,02,00,48,00,03,00,00,00,00,00,14,00,8d,01,02,00,01,01,00,00,00,00,00,\
  05,0b,00,00,00,00,00,18,00,ff,01,0f,00,01,02,00,00,00,00,00,05,20,00,00,00,\
  20,02,00,00,00,00,14,00,fd,01,02,00,01,01,00,00,00,00,00,05,12,00,00,00,01,\
  01,00,00,00,00,00,05,12,00,00,00,01,01,00,00,00,00,00,05,12,00,00,00
c. Save the file as .reg file on the desktop.
d. Right click .reg file and select run as administrator.
e. Click yes, when message prompts.
Note: Serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
http://windows.microsoft.com/en-us/windows/back-up-registry
I hope this helps.
Thank you
52 additional answers
    2011-06-17T13:36:00+00:00
    I can confirm the same problem. PDFs get stuck in the print spool and the spooler stops. Its only with PDFs and only certian PDFs and only with one HP printer. I clear the spool and it works OK, until the next time.
    • C Thomas
    2011-06-17T13:38:14+00:00
    Not the only ones with this problem. This person changed PDF Readers to solve his problem. Sounds liek the issue might be with Adobe.  i will try uninstalling and reinstalling it.
    http://blog.twinbytes.ca/2010/08/05/resolved-hp-laserjet-1018-print-spooler-stops-when-printing-scanned-pdfs/
    2011-06-17T14:26:52+00:00
    Your thoughts are where research got me to a couple of days ago. The problem is that it happens here with a copy of Foxit on my computer and no copy of Adobe Reader. The source of the pdf file is obviously implicated as pdf files provided by my HP Scanjet 5590P give the printer no problem.
    I am waiting for the next email from a particular supplier to secure a copy of a file which usually causes the spooler to stop. Another similar computer I have access to handles the problematic pdf file attachment without the spooler stopping.
    What might be a line of enquiry is that  the problem arises when opening and printing from a web browser (Internet Explorer 9 ) whereas the one without the problem opens the attachment for printing after downloading to Outlook 2010.
    I do have Adobe Flash on the computer but this does not open pdf files for printing.
