wireless network adapter gone missing
2010-01-26T05:41:47+00:00
Hi -
I've seen a number of similar questions but no solutions to my problem.
My system:
Toshiba A505-S6980
Windows 7 Home Premium - 64bit
Realtek WLAN driver
Problem:
After resuming from a sleep, the network adapter dissappeared.  This happened before and they replaced the computer, after trying a system restore and then full recovery.  Apparently, it's not the computer.
The Wireless adapter is missing from device manager, much less the network and connections area.  In troubleshoot, the computer simply says a network cable needs to be plugged in.  There is no wireless choice under network connections.  There is no wireless adapter tab upon right click of Network Adapter in Device Manager.
The Realtek WLAN driver DOES appear in the Programs & Features list.  I uninstalled, reinstalled, and also found/installed a patch for the driver.  This did not work.  I also started/automated the Autoconfig scripts for wireless.  Nothing works.
Any help is appreciated.
-Tucson56
2015-05-07T04:30:16+00:00
Hi '
This just happened to me and I was able to get past it by doing several hard reboots. I had to fully charge the battery , and after three attempts with increasing intervals of time, the system appearently turned the wireless adapter back on.
After the card reappeared, I was able to find it in device manager again, in my case Intel(R) Centrino(R) Wireless-N 2200 under network adapters . Then a right click, to properties , within properties you chose power Management tab. There you will probably discover that by default the computer is allowed to turn off this device to save power. Uncheck the box , click ok and reboot . Hopefully this will prevent it from happening again.
Hope this helps
Art Master T
2015-01-09T14:23:36+00:00
This same thing happened to me. What causes it to happen is a very low battery but found a simple solution to turn back on the wireless network adapter.
Hold down the Windows key and press x
menu should come up
click device manager
should go to a list of devices on your computer
expand network adapters from list
might be a few to choose from but look for 2 with the same name. one for wifi and one for ethernet
double click on the wifi network adapter
click on power management tab
click off the tab that allows the wifi to be turned off with low battery
click on drivers tab and enable device
should be good to go from there
2010-01-27T20:25:00+00:00
Hi tucson56, A. From how long do you face this problem? I would suggest you to check for the power management settings for your wireless adaptor and see if that help. 1.Open Network and Sharing Center (click the Start button, type Network and Sharing in the Start Search box, and press Enter) 2.Click the Change adapter settings link in the upper left of the navigation pane. 3.Right click the network connection you want to enable/disable power management support on and click Properties. 4.Click Configure. 5.On the Power Management tab, check or clear the Allow the computer to turn off this device to save power check box. A. When checked, power management is enabled on the network adapter. B. When cleared, power management is disabled on the network adapter. 6.You can enable Wake on LAN for all wake methods or just enable magic packet WoL: To enable Wake on LAN for all methods, check the Allow this device to wake the computer check box. To enable Wake on LAN for magic packet only, check the Allow this device to wake the computer check box and then check Only allow a magic packet to wake the computer check box. 7.Click OK. Additional information:
http://technet.microsoft.com/zh-cn/library/ee617165(WS.10).aspx
Hope this helps. Let us know the results.
Thanks & Regards,
Vijay B – Microsoft Support
92 additional answers
    2013-08-28T21:51:47+00:00
    Well I have mentioned some of the troubleshooting in my previous link you can check the BIOS settings of the laptop if you have tried everything because I got many laptop having same issue in most of the cases this helped me
    I have mentioned some more troubleshooting in my this post
    Wireless connection icon missing
    Sorry but all your links are dead! Could you reup them please?
    2013-10-22T06:14:16+00:00
    I had this same problem a few days ago, drove me nuts. Checked other Websites, fixes & threads, found nothing. I'd Recommend manually disconnecting the WLAN receiver (A small card inside the laptop attached to the Motherboard w/ 2 wires running into the monitor, usually located near the RAM), restarting it, checking your BIOS, reinstalling the WLAN card and restarting it again. Tried it and it worked for me. Hope it works for you all too.
    HP-G7-2118nr
    AMD-A6 APU
    Radeon HD 7250
    Win 7 64bit / Fedora 18
    4GB 1600MHz
    750GB 7200RPM
