Right click 'Open With' Command missing. Help Please.
2009-09-21T20:08:24+00:00
I realised a few days ago that the right click context menu 'open with' command is missing. However its there at the top of the window on the 'menu bar' or whatever.
Not sure how it happened. Maybe when i installed MS .Net Framework 3 SP1 or maybe when I cleaned registry with CCleaner.
I need to get it back please. Could u tell me how??? thanks.
2009-09-22T12:20:29+00:00
Hi, scurvy:
By design, the Open With menu option is not available when you right-click executable files (.cmd, .bat, .pif, .scf, .exe, .com, or .scr), or shortcuts to executable files.
If you've lost the Open With menu option for ALL file types, including non-executable files, follow this steps:
  1. Click Start, All Programs, Accesories, Notepad.
  2. Copy and paste this text:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\Open With]
@="{09799AFB-AD67-11d1-ABCD-00C04FC30936}"
  1. Click File, Save As, name the file "OpenWith.reg" (WITH THE QUOTATION MARKS) and click OK.
  2. Now double-click OpenWith.reg, click Continue, Yes, OK, and see if the problem is solved.
P.S: My personal advice is not to use ANY registry cleaner on the system.
Microsoft MVP Windows Desktop Experience
100 additional answers
    2014-01-24T16:14:15+00:00
    tThanks, this is really wonderful.
    2014-05-16T19:46:57+00:00
    When I try to open Notepad it also defaults to the wrong executable and will not open.
    2014-05-30T17:17:10+00:00
    Thank you. It worked. Thanks also for the advice about using Registry cleaner. I was using them until now.
    mals48323
    2014-06-18T10:21:33+00:00
    This wasn't the forum I found when looking before a reboot, but that forum's solutions did not help.
    Merging this registry file fixed it.
    http://www.sevenforums.com/tutorials/52833-open-context-menu-item-add-remove.html
    I'm win 7 64bit - there are several different registry versions with the same name, some of which did not work for me.  The contents of the merge file ate:
    [HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\Open With EncryptionMenu]
    @="{A470F8CF-A1E8-4f65-8335-227475AA5C46}"
    Hope that helps someone.
    Lx
