Right click 'Open With' Command missing. Help Please.
2009-09-21T20:08:24+00:00
I realised a few days ago that the right click context menu 'open with' command is missing. However its there at the top of the window on the 'menu bar' or whatever.
Not sure how it happened. Maybe when i installed MS .Net Framework 3 SP1 or maybe when I cleaned registry with CCleaner.
I need to get it back please. Could u tell me how??? thanks.
2009-09-22T12:20:29+00:00
Hi, scurvy:
By design, the Open With menu option is not available when you right-click executable files (.cmd, .bat, .pif, .scf, .exe, .com, or .scr), or shortcuts to executable files.
If you've lost the Open With menu option for ALL file types, including non-executable files, follow this steps:
  1. Click Start, All Programs, Accesories, Notepad.
  2. Copy and paste this text:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\Open With]
@="{09799AFB-AD67-11d1-ABCD-00C04FC30936}"
  1. Click File, Save As, name the file "OpenWith.reg" (WITH THE QUOTATION MARKS) and click OK.
  2. Now double-click OpenWith.reg, click Continue, Yes, OK, and see if the problem is solved.
P.S: My personal advice is not to use ANY registry cleaner on the system.
Microsoft MVP Windows Desktop Experience
100 additional answers
    2013-10-16T14:45:26+00:00
    That worked!  TY!
    2013-11-08T05:14:32+00:00
    still I cannot see open with option in medias such as mp3 avi mp4 so and so.. what shall I do?
    plz help.
    Thanks in advance..
    2013-12-06T11:16:58+00:00
    You should have an entry "Edit" in the right-click context menu for CMD and BAT files. This will open those files in Windows Notepad for editing.
    2013-12-06T13:24:18+00:00
    The problem is, on the Win7 computer where I don't have the 'Open With', clicking on edit for a batch file 'runs' the file.   Even though it says edit, it actually runs it.  The only way I can edit a batch file on this machine is by doing it through a cmd window.
