Right click 'Open With' Command missing. Help Please.
2009-09-21T20:08:24+00:00
I realised a few days ago that the right click context menu 'open with' command is missing. However its there at the top of the window on the 'menu bar' or whatever.
Not sure how it happened. Maybe when i installed MS .Net Framework 3 SP1 or maybe when I cleaned registry with CCleaner.
I need to get it back please. Could u tell me how??? thanks.
2009-09-22T12:20:29+00:00
Hi, scurvy:
By design, the Open With menu option is not available when you right-click executable files (.cmd, .bat, .pif, .scf, .exe, .com, or .scr), or shortcuts to executable files.
If you've lost the Open With menu option for ALL file types, including non-executable files, follow this steps:
  1. Click Start, All Programs, Accesories, Notepad.
  2. Copy and paste this text:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\Open With]
@="{09799AFB-AD67-11d1-ABCD-00C04FC30936}"
  1. Click File, Save As, name the file "OpenWith.reg" (WITH THE QUOTATION MARKS) and click OK.
  2. Now double-click OpenWith.reg, click Continue, Yes, OK, and see if the problem is solved.
P.S: My personal advice is not to use ANY registry cleaner on the system.
Microsoft MVP Windows Desktop Experience
100 additional answers
    2013-07-23T15:51:37+00:00
    I recently had a virus and McAffee removed virus. Now my Open with is now missing. I tried the note pad trick, it just opens notepad. Its very frustrating that this is missing now. I have no idea what McAffee did to undo it. I also have been using Ilio System Mechanic  - but I was still always able to Open With until the virus episode. Any help is appreciated.
    2013-07-23T19:56:00+00:00
    I do not have this in my registry folder, I found up to shellex, but there was no ContextMenuHandlers in my registry.
    2013-08-28T19:17:05+00:00
    Thanks.  Worked perfectly.
    I know this was a little inconvenience, but annoying.
    Again, thanks
    2013-10-15T07:11:20+00:00
    WoW. Great and simple fix. very useful.
