Right click 'Open With' Command missing. Help Please.
2009-09-21T20:08:24+00:00
I realised a few days ago that the right click context menu 'open with' command is missing. However its there at the top of the window on the 'menu bar' or whatever.
Not sure how it happened. Maybe when i installed MS .Net Framework 3 SP1 or maybe when I cleaned registry with CCleaner.
I need to get it back please. Could u tell me how??? thanks.
2009-09-22T12:20:29+00:00
Hi, scurvy:
By design, the Open With menu option is not available when you right-click executable files (.cmd, .bat, .pif, .scf, .exe, .com, or .scr), or shortcuts to executable files.
If you've lost the Open With menu option for ALL file types, including non-executable files, follow this steps:
  1. Click Start, All Programs, Accesories, Notepad.
  2. Copy and paste this text:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\Open With]
@="{09799AFB-AD67-11d1-ABCD-00C04FC30936}"
  1. Click File, Save As, name the file "OpenWith.reg" (WITH THE QUOTATION MARKS) and click OK.
  2. Now double-click OpenWith.reg, click Continue, Yes, OK, and see if the problem is solved.
P.S: My personal advice is not to use ANY registry cleaner on the system.
Microsoft MVP Windows Desktop Experience
100 additional answers
    2013-03-19T01:53:31+00:00
    Thank you very much.  This worked for me perfectly.
    Regards,
    John
    2013-03-28T20:35:58+00:00
    Applied this fix to my registry, and it did "take" -- but it didn't solve the problem.  My right-click menus on all files shows "Open With ..."  rather than "Open With" with a submenu caret.
    In my case, there's a related issue:  if you click the "Open With ..." menu item, it gets you to a dialog box allowing selection of applications you can add to the Open With list.  But that list is always wrong, as the file extension has a quotation mark added at the end (e.g., file.txt is shown as file.txt" in the Open With selector dialog).
    When I select a program in that Open With dialog, it does NOT go into the open-with list for either the original file extension (in the example, .txt) or the new fake one (in the example, .txt")...so the original "Open With..." menu item never does the right thing.
    Ideas?????
    This is clearly caused by CC's registry cleaner ... sigh...
    2013-03-28T21:10:56+00:00
    Programs like CC usually have an undo feature.
    2013-04-09T13:50:48+00:00
    WOW!!! it worked perfect on my end... Thank you. And also for the good adice on registry cleaning.
