Right click 'Open With' Command missing. Help Please.
2009-09-21T20:08:24+00:00
I realised a few days ago that the right click context menu 'open with' command is missing. However its there at the top of the window on the 'menu bar' or whatever.
Not sure how it happened. Maybe when i installed MS .Net Framework 3 SP1 or maybe when I cleaned registry with CCleaner.
I need to get it back please. Could u tell me how??? thanks.
2009-09-22T12:20:29+00:00
Hi, scurvy:
By design, the Open With menu option is not available when you right-click executable files (.cmd, .bat, .pif, .scf, .exe, .com, or .scr), or shortcuts to executable files.
If you've lost the Open With menu option for ALL file types, including non-executable files, follow this steps:
  1. Click Start, All Programs, Accesories, Notepad.
  2. Copy and paste this text:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\Open With]
@="{09799AFB-AD67-11d1-ABCD-00C04FC30936}"
  1. Click File, Save As, name the file "OpenWith.reg" (WITH THE QUOTATION MARKS) and click OK.
  2. Now double-click OpenWith.reg, click Continue, Yes, OK, and see if the problem is solved.
P.S: My personal advice is not to use ANY registry cleaner on the system.
Microsoft MVP Windows Desktop Experience
100 additional answers
    2010-11-12T15:40:28+00:00
    I have this same problem with Windows 7 and Aashish G 's answer doesn't seem to work.  I get an error when I double click**"OpenWith.reg".**
    Got it now I neglected to add "Windows Registry Editor Version 5.00" to the .reg file.  Thanks it works like new.
    2010-10-23T22:58:46+00:00
    Thanks so much. It worked perfect.
    2010-02-09T06:17:11+00:00
    Seconded, i want to chose what application i open the file with and the 'open with' was an exellent feature in xp but its not present(by default) in win 7
    2009-11-29T02:52:01+00:00
    How can I get the Open-With submenu to work for executable files? I don’t want to run self-extracting executables by running the file, I want to open it with the 7Zip file manager (so that I can look inside archive). I am able to add and use the Open-With context menu item for EXE files, but there is no Open-With submenu—to give quick access to open the EXE with 7Zip, WinRAR, hex-editors, etc.
