Xbox 360 Controller plugged to USB with "Play and Charge Kit" does not work
2009-10-21T17:07:28+00:00
Hello, i've Windows 7 as O.S, and i'm having some problems with my Xbox 360 controllers. When i've bought the play and charge kit for my xbox 360 controller, i heard that it was possible to connect it to te pc in order to play with games for windows live. So, i've started to look for drivers, and i found them in microsoft's hardware official site. I've installed them, then i've restarted my p.c, i plugged in the USB, WIndows recognized the hardware. I thought it was alright. But, even if the hadrware has been recongnized, it doest work. Then I've discovered that "Xbox 360 Accesories 1.2" does't recognize the hardware, and it is not recognized as a gaming Hardware, but as a generic Hadrware.  at that point i've gived up! I've surfed in the internet, trying to find somethig or somemone able to help me, but it was useless. Now i hope you'll be able to solve my problem!
P.S: I've alredy tried to change controller, to change USB port, to change cable, to uninstall and repeat the driver's installation...
Hope i've been clear, and sorry for my bad english!
Windows for home | Previous Windows versions | Gaming
2009-10-21T18:22:59+00:00
Hello TheRick.
Unfortunately this won't work.  The Play and Charge kit only connects up to the actual battery.  The controller still connects over wireless.
You'd need either a wired Xbox 360 controller, or a Xbox 360 Wireless Gaming Receiver which will connect to your existing wireless controller.
Paul Smith - MVP for Windows Desktop Experience... I've crawled off NNTP - for now. Posting from Aldershot, UK. On the internet at windowsresource.net and dasmirnov.net. Please post back letting us know what works and what doesn't. :-)
60 additional answers
    2013-08-14T20:17:47+00:00
    what OS did u use? I am attempting this on windows 8 and it does not work
    2013-08-22T09:20:30+00:00
    If you want you computer to recognize a controller as a xbox 360 controller instead of unknown device you can manually get the driver for that. here's a basic tutorial:
    click 'start'
    right click 'computer'
    click 'manage'
    go to 'device manager'
    find your controller, it should be named unknown device at this point
    right click it and update driver software
    browse my computer for driver software
    let me pick from a list of device drivers on my computer
    Microsoft Common Controller For Windows Class
    Xbox 360 Wireless Controller via Play & Charge Kit
    There ya go, in my experience it allows the controller to charge properly and enables the red/ green light when it is charging or full.
    Only 4 years late.....
    2013-09-12T04:01:50+00:00
    study 6 years yet he can't debug winblows... lmfao
    2013-09-20T02:03:32+00:00
    with all due respect... are you high?  the play and charge is NOT just a charger. It IS in fact a proprietary M$ DATA TRANSFER cable used for powering the Xbox 360 controller WHILE playing...  It doesnt work on the PC BC Windows doesnt recognize the damn thing... it is that simple... -_-
