Ctrl c not working
2009-05-11T08:55:36+00:00
Hello, somehow I have managed to disable the shortcuts for cutting and pasting. I can only do it manually through the menu bar. I cannot Ctrl C or Ctrl V anymore - nothing happens! What have I done? Please help.
thanks
Nicole
(am using Word 2003)
2010-02-03T00:02:47+00:00
Annoying problem if you rely 100% on keyboard shortcuts!  I had the same problem and the fix is very easy.  You will need to uninstall your keyboard driver and restart your computer and your CTRL keys will function once again.  To do this:
1)  Click Start
2)  Control Panel
3)  Printers and Other Hardware
4)  Keyboard
5)  In the Keyboard Properties window, click Hardware
6)  Click Properties
7)  Click Driver
8)  Click Uninstall, click OK
9)  Restart your Computer
900+ people found this answer helpful.
2009-05-13T16:02:40+00:00
Hello nicbar35,
 Thank you for your reply back!
 Is this only happening in Microsoft Word or does this also occur in other programs like 'Notepad"?  I went to Microsoft Word support and am showing commands listed below.  Again, if only happening within Word, I would suggest going to site listed.
Keyboard shortcuts for Word and support:http://office.microsoft.com/en-us/word/HP051866641033.aspx?pid=CH060831551033
Character and paragraph formatting
To do this Press
Copy formatting from text. CTRL+SHIFT+C
Apply copied formatting to text. CTRL+SHIFT+V
James Microsoft Answers Support Engineer Visit our Microsoft Answers Feedback Forum and let us know what you think.
153 additional answers
    2017-02-20T16:09:53+00:00
    This was for the old version in 2010 now in the new PC the model and the names have changed a little.so there is some same steps and there are some different names.for the 2016-2017 you will need to follow these steps:
    1)  Click "Start"
    1.  click "Control Panel"
    2. Double click on "Devices and Printers"
    3. Double click "USB Receiver"
    4. Click on "Hardware"
    5. Click on "HID Keyboard Device"
    6. Click on "properties"  on the bottom
    7. Click "Driver" on the top
    8. Click uninstall
    9. Restart your computer!
    have fun!
  2. Deleted
    2017-03-14T06:29:11+00:00
    I was having this problem too, but turns out you just need to install proper driver.
