Ctrl c not working
2009-05-11T08:55:36+00:00
Hello, somehow I have managed to disable the shortcuts for cutting and pasting. I can only do it manually through the menu bar. I cannot Ctrl C or Ctrl V anymore - nothing happens! What have I done? Please help.
thanks
Nicole
(am using Word 2003)
2010-02-03T00:02:47+00:00
Annoying problem if you rely 100% on keyboard shortcuts!  I had the same problem and the fix is very easy.  You will need to uninstall your keyboard driver and restart your computer and your CTRL keys will function once again.  To do this:
1)  Click Start
2)  Control Panel
3)  Printers and Other Hardware
4)  Keyboard
5)  In the Keyboard Properties window, click Hardware
6)  Click Properties
7)  Click Driver
8)  Click Uninstall, click OK
9)  Restart your Computer
900+ people found this answer helpful.
2009-05-13T16:02:40+00:00
Hello nicbar35,
 Thank you for your reply back!
 Is this only happening in Microsoft Word or does this also occur in other programs like 'Notepad"?  I went to Microsoft Word support and am showing commands listed below.  Again, if only happening within Word, I would suggest going to site listed.
Keyboard shortcuts for Word and support:http://office.microsoft.com/en-us/word/HP051866641033.aspx?pid=CH060831551033
Character and paragraph formatting
To do this Press
Copy formatting from text. CTRL+SHIFT+C
Apply copied formatting to text. CTRL+SHIFT+V
James Microsoft Answers Support Engineer Visit our Microsoft Answers Feedback Forum and let us know what you think.
153 additional answers
    2016-05-10T21:54:40+00:00
    Hello, sometimes you may just need to uninstall your keyboard driver and restart your computer, as technology bridge said. I had a similar issue when I couldn't use CNTRL V. What I found out is that in skype my bind key for mute was control v, so i couldn't use CNTRL v when skype was on. So what you could do is just change your bind keys for other programs. Notice this only happens when the program with the bind key CNTRL V is open. If its closed you should have no problem .
    2016-06-13T08:35:19+00:00
    Hi
    I followed steps 1 to 7. Uninstall option is locked. What should I do?
    2016-06-14T21:02:20+00:00
    Hello nicbar35,
    I have been having this problem for about seven or eight months now. I was trying all sorts of things> I updated my drivers. Uninstalled my drivers. Reinstalled drivers and just hit CTRL+V seven thousand times. Nothing would work no matter what I tried. I was sitting in my computer chair frustrated with my feet up on my desk. I Restarted my computer so I tried one more time to click CTRL+V. It worked! It turns out my foot was on the shift key while I hit CTRL+V! So now all I have to do is hit CTRL+Shift+V to paste! Hope this Helps! :D
    -Connor
