Ctrl c not working
2009-05-11T08:55:36+00:00
Hello, somehow I have managed to disable the shortcuts for cutting and pasting. I can only do it manually through the menu bar. I cannot Ctrl C or Ctrl V anymore - nothing happens! What have I done? Please help.
thanks
Nicole
(am using Word 2003)
2010-02-03T00:02:47+00:00
Annoying problem if you rely 100% on keyboard shortcuts!  I had the same problem and the fix is very easy.  You will need to uninstall your keyboard driver and restart your computer and your CTRL keys will function once again.  To do this:
1)  Click Start
2)  Control Panel
3)  Printers and Other Hardware
4)  Keyboard
5)  In the Keyboard Properties window, click Hardware
6)  Click Properties
7)  Click Driver
8)  Click Uninstall, click OK
9)  Restart your Computer
900+ people found this answer helpful.
2009-05-13T16:02:40+00:00
Hello nicbar35,
 Thank you for your reply back!
 Is this only happening in Microsoft Word or does this also occur in other programs like 'Notepad"?  I went to Microsoft Word support and am showing commands listed below.  Again, if only happening within Word, I would suggest going to site listed.
Keyboard shortcuts for Word and support:http://office.microsoft.com/en-us/word/HP051866641033.aspx?pid=CH060831551033
Character and paragraph formatting
To do this Press
Copy formatting from text. CTRL+SHIFT+C
Apply copied formatting to text. CTRL+SHIFT+V
James Microsoft Answers Support Engineer Visit our Microsoft Answers Feedback Forum and let us know what you think.
153 additional answers
    2009-05-18T08:49:31+00:00
    Hello, it is only happening in Word. I don't know if I have Windows Live Mail client application, sorry. I will visit the link suggested above. Many thanks all.
    2009-07-03T10:26:11+00:00
    Hi,  I've been having the same problem with Office 2007 on my desktop running Vista Ultimate (no such problem with my laptop running Vista Home Premium).  Sometimes ithe shortcuts work and other times not.  The problem seems to have coincided with a recent Windows Update but I can't say for sure.  So I don't you have done anything wrong.
    Ratdoc
    2009-07-23T13:45:28+00:00
    I have the same issue, and it is in all programs, even Firefox. This happened after i updated Silverlight. Ctrl+Insert, which is not a terribly easy keystroke, works to copy, but I still can't paste with a keystroke. i have Windows xp 64bit.
